RGB Channels
Based on version 11V.
Introduction to RGB
RGB lighting, both dumb and smart pixels, have added a large amount of complexity and channel counts in displays.  HLS is very advanced in handling RGB channels. This section of the wiki will discuss setting up channels, converting multiple channels into one, and how to use the RGB features for other display items.
Adding RGB Channels
Another example when this may come in handy is when you have imported a sequence from Vixen or LOR which contains three separate RGB channels that you now want to combine into one.
To convert three R, G, B channels into one:
 - Verify that the three channels you wish to convert are setup properly. (See Figure 3-25)
- Open the Converter for RGB (Click Manage Channels -> Auto Convert Channels to RGB. (See Figure 3-26)
- Place the Red Channel in Red, Green Channel in Green, and Blue Channel in Blue. (See Figure 3-27)
- A dialog will open with information about how many channels have been converted. (See Figure 3-28)
- Open HLS and open the Channel Manager to see the newly converted channel(s). (See Figure 3-29)
 - Click OK.
Red, Green, and Blue "mega strings" aren't the only grouped strings that can benefit from the RGB single channel conversion. If your colors are different from those, you can still use the RGB channel to reduce channel count by 2/3. As an example, imagine a Mega tree with 16 strings of red, white, and blue lights (48 strings total). If those mega strings were converted to single RGB channels, the channel count would go from 48 to 16.
- Follow the conversion steps above to convert the multiple channels into RGB channels. Except this time, Red goes to red, WHITE goes to green, and Blue goes to blue.
 - When programming, use red effects for the red lights, blue effects for blue lights, and GREEN effects to control the white lights.
 - If you program white in the RGB channel, then all three colors (red, white, and blue) would be on.
 - Think of the RGB string as three channel control rather than only red, green, and blue control.
| Advanced Channel Management | Chapter 3: Channel Management | Configuring Display Groups |
