Setting up Channels
The following tutorial was based on Version 11V
In Figure 1-8.3 the channel names are now Ch_0001, through Ch_0024. We are going to change the names to reflect their use.
In this example we will have two trees: Tree_1 and Tree_2. Each tree will have 3 outputs; red, green and blue.
To rename the outputs first Click the "UnFreeze Name to Edit" check box above the Channel name column. This allows you to edit the channel names directly. After UnFreezing the name column the channel window may shift to the right. If so you just need to move the lower scroll bar back to the left to see the channel names again. Now all you have to do is click in each channel name you want to change and type in what you want. You can use cut and paste from one cell to another. There are other ways to rename channels which are much easier for large numbers of channels but for this example the easiest way is to directly rename them. Rename them as shown in the example in Figure 1-8.5.
The color was chosen for each output next. The color will be shown in the simulation.
To set the color for an output click the color block in the upper right of the screen. This will open the color picker as shown below.
Select the color Red (it will already be red by default) by clicking the "Make Red" button. This will close the color picker window. Next, right click in the cell under the "Color" column that you want to color. In our case we right click on the first row making it red. Do the same for the green and blue channels. You will end up with the
Next right click in the desired channel row Color cell and it will change to the chosen color.
The same process was followed to assign the green and blue colors to the corosponding outputs (see figure 1-9)
We are now finished with this screen, click on the Save All Changes button.
Next: Configuring Groups
