Mirroring Effects
Based on Version 11V.
Mirroring is taking an effect or group of effects,and flipping them horizontally or vertically.
Horizontal Mirror:
- Enter Selection mode and select the group of effects to mirror (see Figure X-X).
 - Note: Remember, to select effects, you must CTRL-left-click.
 - Right-click on the group and press CTRL+H or select Flip Horizontal Selection Box (see Figure X-X).
 - Tip: If you create a selection box longer than the object to be flipped, HLS will flip and move it to the right-most cells.
Vertical Mirror:
- Enter Selection mode and select the group of effects to mirror.
 - Right-click on the group and press CTRL+M or select Flip Vertical Selection Box (see Figure X-X).
 - Tip: If you create a selection box taller than the object to be flipped, HLS will flip and move it to the furthest away cells.
