Creating Basic Effects
Pictures will be added soon.
Based on Version 11V.
Complete this section.
The Window and it's components
The Toolbar and relevant buttons
Selection Mode in HLS
Basic Method to Create a Selection Box:
 - All of the cells you have chosen will be surrounded by a dotted line. (See Figure 4-X).
Basic Effects
Level:
- Shortcut key: L
Ramp Up:
- Shortcut key: U
Ramp Down:
- Shortcut key: D
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
 - Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
Modify Effect Attributes:
 - Right-click an effect and select Modify Effect. The Modify Effect window will appear (See Figure 5-X).
