Different Styles of Pixels
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8806
- LPD8809
- SM16715
- SM16716 -4 wire (can drive 3 channels, or 1 RGB LED) Datasheet (Chinese)
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
| String | WS2801 | 50 pixels (6m) | 5vdc | 10 | 10 | link | $26.00 | $0.52 | IP68 | |
| String | WS2811 | 50 pixels (6m) | 5vdc | 10 | 10 | link | $24.25 | $0.49 | IP68 | |
| String (Square) | WS2811 | 50 pixels (6m) | 12vdc | 10 | 10 | link | $25.75 | $0.52 | IP68, back wire | |
| Module (Rectangular) | WS2811 | 20 pixels (2m) | 12vdc | 10 | 10 | link | $16.75 | $0.84 | 3 LEDs | |
Light-O-Rama (LOR)
(USA Based)
| String | LPD6803 | 100 pixels (15.25m) | TBDvdc | 6.5 | 6.5 | link | $239.95 | $2.40 | Cosmic Color Pixels (with controller and Power Supply) | |
| Bulbs | LPD6803 | 100 pixels (15.25m) | TBDvdc | 6.5 | 6.5 | link | $289.95 | $2.90 | Cosmic Color Bulbs (with controller and Power Supply) | |
| Strip | LPD6803 | 50 pixels (5m) | TBDvdc | 30 | 10 | link | $249.95 | $2.50 | Cosmic Color Ribbon (with controller and Power Supply) |
Ray Wu
(China Based)
| Strip | TM1809 | 240 pixels (5m) | 12vdc | 48 | 16 | link | $67.00 | $0.28 | IP68, silicone tube |
Retail Store (i.e. Lowes)
| String | GECE | 25,36,50 pixels (20,29,41ft) | 5vdc | 4 | 4 | link | ~$2 | G35 Cover, General Electric Color Effects |
Seasonal Entertainment
| String (square) | WS2801 | 42 pixels (8.4m) | 12vdc | 5 | 5 | link | $43.00 | $1.02 | IP68, Rainbow C7 Pixels | |
| String (square) | WS2801 | 42 pixels (8.4m) | 12vdc | 5 | 5 | link | $45.00 | $1.07 | IP68, Rainbow C9 Pixels | |
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $32.50 | $0.65 | ||
| Strip | None | 5m | 12vdc | 30 | 0 | link | $49.99 | $10.00/m | silicone tube and coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $25.80 | $1.29 | 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $27.80 | $1.39 | 3 LEDs |
Ray Wu
(China Based)
