[Back to HLS Main Page]
This User Manual and Reference Guide is a detailed guide to using all aspects of HLS. It is currently under significant development. To quickly get up and running with a sequence, you may want to look at the HLS Getting Started Manual.
Getting HLS
Download and Installation
Upgrading HLS
Creating a Sequence
Starting a new HLS Sequence
Audio File
Time Resolution
Channel Management
Setting up HLS Channels
Configuring Display Groups
Adding and Deleting Channels
RGB Channels
Pixel Channels
Converting 3 Channels into a Single RGB Channel
Using Folders
Displaying a Group in the Main Window
Importing and Exporting
Comma-Separated Values (CSV)
Importing a Sequence from Vixen
Importing a Sequence from LOR
Moving or Sharing Sequences
Sharing Library Effects
Display Preview
Creating a Display Preview
Dimming Curves
Dimming curves can be used to give the appearance of a more "natural" ramp on and off to LED lights.
Setting up Dimming Curves
Adding and Using Beat Tracks
Creating Basic Effects
Setting Defaults for Level, Ramps, and min/max out
Creating Chase Effects
Mirroring Effects
Fill Effects
Over Control Ramp
Custom Effects
Creating a Library of Group Effects
The PixelPlane
A PixelPlane is a single channel in the sequence editor that represents multiple pixels. This allows macro control of pixels, with the ability to "drop" effects onto a plane, such as with Nutcracker, and manipulate the entire effect as if it was one channel.
PixelPlane Editor
MegaTree
Sequence Playback
Outputting the Sequence
Hardware Configuration
Selecting the Output Method
Working with Playlists
Trigger Events
RDS Output
Servo Motors
