E1.31 Bridge
This is a work in progress!!!!
6 Port E1.31 Bridge Parts
| Mouser BOM | ||
The 6 Port E1.31 Bridge requires a fair bit of soldering so take your time and ensure you install the components in the correct orientation when required. Start by sorting the components by type and values. Look over the PCB before starting noting the location of the various components. Follow the standard procedure of installing the lowest profile parts first and ending up with the tallest.
- Install the 0.1uF (100nF) capacitors C4-C12.
 - Install the 220 Ohm resistors R1-R3.
 - Install the 120 Ohm resistors R4-R9.
 - Install the 10K Ohm resistors R10-R12
 - Install the 5Mhz Crystal X1.
 - Install the Toggle Switches S1-S2.
 - Install the seven 8 Pin IC sockets and one 40 pin socket.
 - Install the green LED LED1.
 - Install the red LEDs LED2-LED3.
 - Install the 3.3V Regulator VR2 with the heat sink.
 - Install the 3 Pin and 4 Pin headers JP1, H1.
 - Install the two WizNet 1x6 pin headers.
 - Install the twelve 2x3 output pin selectors.
 - Install the power terminal block TB1.
 - Install the three 47uF Capacitors C1-C3.
 - Install the DC-DC Converter VR1.
 - Install the six RJ45 jacks J1-J6.
 - Install the six RT485BN in IC3-IC8 with the notches facing the edge with the power terminal block.
 - Install the EEPROM in IC2 with the notch facing the edge with the power terminal block.
 - Install the Propeller in IC1 with the notch facing the WizNet adapter.
 - Install the WizNet adapter with the socket facing the Propeller IC.
H2 and IC9 will be unpopulated as these are both for future expansion.
Initial Testing
Programming the EEPROM
Current version of the firmware is v2.02 and you can download it here.
The Programming port on the Bridge is the 4 pin header near the WizNet adapter. Match up the silk screen labels with those on the Prop Plug. You will need to externally power the bridge when programming it.
Programming Tools Required
The reccomended way is to use the PropPlug.
PropPlug
You can get it from DIYLEDExpress during Pre-Sales or find it  at Parallax or Mouser anytime.
Build your own
Programming Howto
- Download the Parallax Propeller Tool and install it.
 - Run the Propeller Tool application and it will ask of you want to associate .eeprom files with the application, Say Yes.
 - You can close the Propeller Tool application and double click on the .eeprom file you downloaded or from within the application go to File->Open and change the 'Files of type' to 'Propeller Applications' and open the Bridge_v2.02.eeprom file.
 - A 'Object Info' screen will open, if not already enabled click 'Show Hex'
 - Program the EEPROM on the Bridge by selecting 'Load EEPROM' and you are done.
Configuration Commands
Save
Load
Boot
IP
IP a.b.c.d where a.b.c.d is any valid IP address
Subnet
Gateway
DNS
If you are only using DHCP (not recommended), you can leave the static IP areas unused.
Network addressing (static or DHCP IP) is only needed to access the configuration
page with a web browser.  Once configured, no IP address is needed for normal operation.
The Default IP Mode, Web Server Mode, No Data Timeout, and Test Pattern commands affect
what happens when the system starts up.
Default
DEfault n where n is 0 or 1. DE 0 sets a default network mode of STATIC, DE 1 sets a default network mode of DHCP.
Universe
Protocol
Baud
The Baud command is used to set the baud rate for each of the four output RJ45 jacks.
NOTE: This command is only used for the Renard protocol. Baud rate will not be displayed when
the DMX protocol is selected.
BAud b n Where b is the RJ45 output jack number, from 1 to 6
and n is 1 for a baud rate of 57,600 or 2 is for a baud rate of 115,200.
The Renard protocol refresh rate at 57,600bps for 512 channels is approximately 90ms and at
115,200bps the refresh rate for 512 channels is approximately 45ms.
The DMX protocol refresh rate is preset to 25ms.
TroubleShooting
Visual Inspection
