Ohm's Law
Revision as of 14:22, 28 October 2012 by Jklingert (talk | contribs) (Power (P))
Ohm's Law
V=IR
Voltage = Current x Resistance
Ohm's Law Diagram
Voltage (V)
  • AC Alternating Current
    • Example:
  • DC Direct Current
    • Example:
      • The voltage of a typical NiMh AA battery is 1.25 volts DC (VDC).
      • Many Integrated Circuits require 5 volts DC (VDC) to power them.
  • Formulas
    • V=IR
    • V=√PR
    • V=P/I
Current (I)
  • Example:
    • A typical string of 100 count incandescent lights draws 0.33A.
  • Formulas
    • I=V/R
    • I=P/V
    • I=√P/R
Resistance (R)
  • Example:
  • Formulas
    • R=V/I
    • R=V²/P
    • R=P/I²
Power (P)
P=VI
Power=Voltage x Current
  • Example:
  • Power Formulas
    • P=VI
    • P=I²R
    • P=V²/R
LED Calculator
By using Ohm's Law you can calculate the current limiting resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
Pixel Voltage Drop Calculator
Thread
