Ohm's Law
Revision as of 05:55, 28 October 2012 by Jklingert (talk | contribs) (Ohm's Law)
Ohm's Law
V=IR
Voltage = Current x Resistance
Ohm's Law Diagram
Voltage (V)
  • AC Alternating Current
    • Example:
  • DC Direct Current
    • Example:
      • The voltage of a typical NiMh AA battery is 1.25 volts DC (VDC).
      • Many Integrated Circuits require 5 volts DC (VDC) to power them.
Current (I)
  • Example:
    • A typical string of 100 count incandescent lights draws 0.33A.
Resistance (R)
  • Example:
Power (P)
P=VI
Power=Voltage x Current
  • Example:
LED Calculator
Use these calculators to calculate the resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
Pixel Voltage Drop Calculator
Thread
Calculator
