Different Styles of Pixels
Revision as of 21:51, 25 October 2012 by Jklingert (talk | contribs) (LED Type)
Pixel Properties
Form Factor
  • Strings (Can be any length, but more then 50 pixels will require power injection)
    1. 12mm pixel nodes
  • Strips (Usually 5M length)
    1. Bare board (no waterproofing)
    2. Hollow Tube
    3. Solid Tube
      • Solid Silicone
      • Solid Epoxy Resin
  • Modules
      • Square
      • Rectangular
LEDs per meter
  • Strips
    1. 30 LED/m
    2. 60 LED/m
  • Strings
    1. 10 LED/m (100mm spacing between nodes is common )
Power Supply Voltage
    1. 5VDC
    2. 12VDC
    3. 24VDC
LED Type
    1. 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
    2. 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
    3. 8mm (typically used in strings)
Waterproofing
(don't trust the IP ratings, they vary quite a bit!) Information about sealing pixel strings
    1. Injection Molded Silicone
    2. Epoxy Resin coated PCB in Silicone
    3. Cast Silicone in Sleeve
    4. Cast Epoxy Resin coated PCB
      • GE Color Effects (GECE)- 3 wire
      • LPD6803 - 4 wire
      • D705 - 4 wire
      • LPD1101
      • UCS6909
      • UCS6912
      • LPD8806
      • LPD8809
      • WS2801 - 4 wire
      • WS2803
      • WS2811 - 3 wire
      • TM1803 - 3 wire
      • TM1804 - 3 wire
      • TM1809 - 3 wire
      • TM1812
      • SM16715
      • SM16716
      • P9813 - 4 wire
      • P9816 - 4 wire
      • HX512A (Native DMX)
      • TLS3001 - 3 wire
      • TLS3002
      • CYT3001
      • CYT3005 - 3 wire
      • MY9941 (Native DMX)
      • MY9942 (Native DMX)
      • MY9943 (Native DMX)
