Different Styles of Pixels
Styles of Pixels
- Form Factor
 - Strips (Usually 5M length)
- Bare board (no waterproofing)
 - Hollow Tube
 - Solid Tube
- Solid Silicone
 - Solid Epoxy Resin
 - Modules
 - Power Supply Voltage
- 5VDC
 - 12VDC
 - 24VDC
 - LED Type
- 3528 surface mount
 - 5050 surface mount
 - 8mm
 - Control chip and number of wires (3 wire= V+,GND,Data) (4 wire=V+,GND,Data,Clock)
- 4 bits per color, 16 dimming levels per color.  (Total Colors = 16x16x16 = 4,096 colors)
- GE Color Effects (GECE)
- LPD6803
 - D705
 - LPD1101
 - UCS6909
 - UCS6912
- LPD8806
 - LPD8809
- WS2801 - 4 wire
 - WS2803
 - WS2811 - 3 wire
 - TM1803
 - TM1804
 - TM1809
 - TM1812
 - SM16715
 - SM16716
 - P9813
 - HX512A (Native DMX)
 - MY994X (Native DMX)
 - 12 bits per color, 4096 dimming levels per color.  (Total Colors = 4096x4096x4096 = 68,719,476,736 colors) (Note: E1.31 and DMX only support 8 bit data, so the extra bits are used for gamma color correction)
- TLS3001
 - TLS3002
 - CYT3005
