What is the TIR Flood?
These are commercial RGB outdoor DMX floodlights designed and sold by TIR Systems Ltd..  They are Model Number: Destiny CG-WGO-RGB-CUS-V2  These lights were originally mounted on the Duke Energy Building and were replaced with other RGB fixtures.  DIYC member rfallatt arranged to buy the lights from the building and offered them to users via a group buy in August 2012.  There was a mixture of working and bad units sold.  The bad units suffered from water entering either the control module or the power supply.  It appears that the water may have wicked up the inside of the power cord and caused the issues.  Some of the bad units had the glass face plate broken. TIR Systems (in Canada) were considered the leader in outdoor LED systems and were also popular with large dance halls. They were a public stock company until 2007 when Phillips purchased them. They appear to have shut down operations in late 2008.  The manufacture date on the units is late 2008, and based on information, they units were removed from service in 2010.
Manufacturer's Description
How does the TIR Flood work?
These are RGB flood lights that are controlled via DMX and possibly via an unidentified ethernet based protocol.  There is a 5 pin XLR DMX connector that comes configured for DMX input only.  Out of the box these units respond to DMX channels 1-3 (RGB) when powered up and connected to a signal source.  The address progeamming packets have been decoded and there are  several ways to program new DMX addresses into the units. These units will fall back to a test sequence if the DMX signal is not applied.  The test sequence is a series of color fades.  The units also come with a ethernet cable attached and the control protocol has not been established for using it.
Dimensions of the TIR Flood
TIR Flood Components
Connectors
The units come equipped with a 15A 125vAC 3 Pin Twistlock power plug, a RJ45 ethernet interface cable and a 5 PIN XLR DMX cable attached.  The power and DMX cable come out of the base of the mounting bracket thru the waterproof cable holders.  The ethernet cable is tucked inside the base of the mounting bracket and has a rubber waterproof sleeve on the end.
Housing
LED Assembly
The flood lights have 48 Luxeon LEDs mounted in a sealed module on the front of the unit.  There are 16 each of Red, Blue and Green.  The LEDs are mounted on two PCB boards. The LEDs are arranged in a 2x6 array for each color on the upper PCB and 1x4 on the lower PCB.  This video shows how to test the LED Assembly when removed from the housing.
Control Module
There is a control module that drives the LEDs and responds to the DMX commands provided to it thru the DMX interface. The Control Module is mounted inside a waterproof housing and is attached to the rear heatsink with a generous amount of heatsink compound.  Inside of the Control Module there are some HEXFETs that appear to be driving the LEDs (IRL510S). There's a LM2676 5V regulator nearby some of these.
Ethernet Module
There is an  ethernet module mounted inside the control module.  The interface to this module has not been identified yet. Technical Information about the Netburner ethernet module.  The NetBurner module uses the ColdFire MCF5282 processor.  Using the Netburner IP program, one user got the following response "MOD5282 Unit: at 192.168.1.47 running :LuminaireFX (3081041) $Date: 2005/02/04 18:42:48 $, $Name: B_Dma6Aug2004_MainTest $".
Power Supply
The power supply is a 100-240 VAC input and 24.5VDC 3.3A output.  The power supply is sealed in a waterproof enclosure and the wires come through the enclosure via waterproof sealing glands.
The power supply has an input power cord on one end and has a red and black 16ga wire on the other end that connects to the control housing.  Midway between the power supply and the control housing there is black shrink wrap on the red and black power leads.  If you carefully remove the heat shrink, you will find blue "bullet" type connectors that can be separated by pulling them apart. With the power cord bullet connectors apart, you can them test the power supply output  to see if the power supply is working.  You can also apply a different 24vdc power supply to the control module to see if it is working.
Mounting Bracket
Disassembling the TIR Flood
Main Body Separation
- Remove the 3 screws with washers near the rounded back edge on both side panels near the bracket attachment.
Between the mounting plate and the enclosure is white thermal grease.  This grease makes quite the mess.
Instead, you can use Isoprophyl Alcohol.  Any Percent purity is fine. This is the stuff that is less than $1 a bottle and available at any drug store or pharmacy section like at WalMart.
It will dissolve the grease and is safe for contact with human skin!  Wear gloves when removing the units to keep the thermal grease off of you.
- Some of the units appear to have been repaired in the field and have large amounts of silicone caulking around the base of the modules. You will need to cut away the caulking with a sharp knife and pull the caulking out with pliers.
 - Loosen the four screws that hold the black plastic housing and base plate to the light housing. You may need to use pliers to remove the screws since they are held in place by heat sink compound. Wear gloves, there is a lot of thermal heat sink compound behind the base plate. Wedge a paint scraper or other thin object between the aluminum base plate on the module and the back housing. Gently pry them apart. The thermal heat sink compound holds the unit tightly in place, but it will pry apart if you have removed the 4 screws and any excess caulking that may be present.
 - Turn the module over and remove the 8 screws that hold the base plate to the black plastic housing.
- Firmly grasp one pin of the plug with a pliers.
 - Gently pull back on the rubber boot while pulling on the plug. It may help to stretch the edges of the boot to make it come out easier. The boot will slide back down the wire off the plug.
 - Unscrew three screws on the face of the plug and unscrew the two screws retaining the cord on the back of the plug.
 - Slide the assembly out and unscrew the three screws holding the wires in.
 - The wire color code is listed here.
TIR Flood Power Requirements
The units come equipped with a 15A 125vAC 3 Pin Twistlock power plug.  At 100% brightness RGB the flood draws 78 watts @116.5vAC.  The internal power supply provides 24vdc @ 3.3A to the control electronics.  A quick test of the current of the Red LEDs shows to be about 760-780 mA when full on.
AC Power Cable
| Conductor | Wire Color |
| Line | Brown |
| Neutral | Blue |
| Ground | Green/Yellow |
Controlling the TIR Flood
The flood comes equipped with a 5 pin XLR DMX connector. Only the  input wires are connected to the XLR connector, but the output wires are also available and they can be soldered to the plug.  The lights can be controlled by sending a DMX signal to the lights on channels 1-3 to control the RGB lights.  It is believed that these floods were controlled by a software package called LuminaireFX.  This is the Control software developed by TIR for this unit. It's a control system for their "TBus" option.
DMX Wire / XLR Connector
The data connection to the flood light is thru a 5 pin Male XLR DMX connector.  Only the input DMX lines are soldered to the plug.  The output wires are in the cable and are active.  The input and output wires connect together in the control module.  There is no DMX termination resistor on the  light.
| DMX IN Shield | Bare Wire in Red Foil | 1 |
| DMX OUT Shield | Bare Wire in Green Foil | NC |
| DMX OUT + | White Wire in Green Foil | NC |
TBD.  The following photos show the highlighted traces on the LED PCBs by LED color.
Internal Wiring Color Codes
| LED Connection | Wire Color |
| Common (+) | Red/Green |
| RED | Red/Black |
| GREEN | White/Black |
| BLUE | Green/Black |
Upper section
| Common (+) | Black/Red |
| RED | White |
| GREEN | Black |
| BLUE | Red |
Lower section
| Common (+) | Orange/Red |
| RED | Orange |
| GREEN | Green |
| BLUE | Blue |
Thermistor
LED Connector
| Pin Number | Wire Color |
| 1 | White |
| 2 | Green |
| 3 | Blue |
| 4 | Red/Black |
| 5 | Orange/Black |
| 6 | Black/White |
| 7 | Green/White |
| 8 | Black/Red |
| 9 | Orange/Red |
| 10 | Red/Green |
| 11 | Black/Red/White |
| 12 | Red/Black/White |
| 13 | Black |
| 14 | Red |
| 15 | Orange |
| 16 | White/Black |
| 17 | Green/Black |
| 18 | Blue/Black |
| 19 | Red/White |
| 20 | Blue/White |
| 21 | White/Red |
| 22 | Blue/Red |
| 23 | Thermistor \ |
Replacement Power Supplies
Replacement Control Modules
Non-OEM replacement for the Control Module options include a DCSSR driven by a controller  such as the REN48LSD, Simple Renard 32 or the REN64.  The REN48LSD and the  Simple Renard RGB+W CAN NOT drive these lights directly due to the high current demand per channel (~0.75A), you must use a DCSSR. A Standalone DMX Controller is available as a replacement controller as well. You must use an additional constant current limiter if you use these controllers.  On the LED board, each color channel consists of three separate LED circuits that each need to be separately  limited to 0.3A each, so you need a total of 9 constant current limiting devices per flood.
 - The units all have a unique serial number that is listed on the label on the front face plate as well as a standalone sticker on the control module.  It looks like: 308-0911.  This number will be necessary for programming the lights.
 - 169.254.236.22 is TIR programming box address.
 - If ControlFX Director does not detect the presence of a DHCP server when connected to your notebook computer, the device will assume a default IP address of 169.254.236.22 and subnet mask of 255.255.0.0.
DMX Address Translation Board
Since these light responds to DMX Channels 1-3 out of the box, a board is under development to respond to any DMX address and translate it to channels 1-3 to drive these floods.  For more info look here.
Documentation
Destiny CG Wiring Schematic
Destiny CG Datasheet
Software
DMX Address Change Software
Thanks to a lot of detective work by the DIYC community the DMX address programming packets have been decoded and you are now able to reprogram the lights to any DMX address.  There are several tools available to set the address:
Reprogramming with just Vixen and an Enttec Pro compatible DMX dongle
Vixen Based Solution using modified PIC
Arduino Based Solution
SX based Solution
Address Packet Generator
Light Management
Light Initilization
Light Design and Emulation
Netburner
IP Setup tool
UDP Terminal Application
TIR Flood Discussion Threads
Initial Thread
TIR Breakout board
DMX Cable Adapter Boards
DMX Address Change Details
Netburner Module
Test Pattern
Outdoor Test
Another outdoor test
Other Photos
