E68X-to-DMX
Revision as of 07:41, 23 July 2012 by Budude (talk | contribs) (Schematic)
E68X-to-DMX Adapter
E68X-DMX Schematic
Board Layout
E68X-DMX Schematic
E68X-DMX Schematic
E68x Configuration
  • Pixel Type of "DMX PIXEL"
  • String Count of 1
  • Pixel Count of 170
The convert must be plugged into the first connector of the group (1-1, 2-1, 3-1 or 4-1) only.
Converter Configuration
The only thing to configure on the board are the 4 Renard/DMX jumpers. The four jumpers must be placed all on the left for DMX wiring or all on the right for Renard wiring. You must install all four of the jumpers or install wire jumpers instead for the converter to work properly.
