SSRneon-G2-LED
The SSRneon is a 4 port AC Solid State Relay (SSR). It is derived from the same basic design that has been in general use by the DIY community for many years. Most of the DIY SSRs are derived from Sean Bowf's original 4 port SSR.  The design has evolved over the years, but the core functions and parts are the same. The SSRneon, SSRoz and SSRez are all such designs.
Safety Features
4.  The 2 ounce copper AC traces are mirrored on both sides of the board.  This allows for greater current carrying capacity. (8 amps)
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
1      504-GMC-8          5mm x 20mm Medium Time Delay Fuses 125VAC 8A Med Time Delay
See above for TA-200 sources.
240VAC Operation
FireGod
Wiring The SSRneon
 Controller Output Pinout
