SSRneon TA-200 Versions
Two versions that fit in the TA-200 Enclosure
The SSRneon-G2 is available in two versions, the SSRneon-G2 and the SSRneon-G2-LED.
Both of these designs share similar layouts and both have the neon bulb indicators for extra safety.
The SSRneon-G2 was available as both a production board and as a home-etchable board.
The SSRneon-G2-LED is only available as a two sided production board.  There is no home etch layout available.
SSRneon-G2 bare PCB
SSRneon-G2-LED bare PCB
Safety Features
1. Dual Neon bulbs that indicate the presence of AC Voltage on both sides of the Fuse !
Order your own boards
The Gerbers for the SSRneon-G2 are found at this link:
Zip File containing the SSRneon G2 Gerber files
The Gerbers for the SSRneon-G2-LED are found at this link:
Zip File containing the SSRneon-G2-LED Gerber files
Home Etch
Fuse Rating
SSRneon-G2 BOM for 120VAC Operation:
QTY  Silkscreen       Mouser #:           Description
2                     606-A9A            Neon Lamp 65VAC .7mA NE-2E
1                     571-5556416-1      Modular Jacks 8 PCB TOP ENTRY marked RJ45
4                        -BTA06-600CW    Triacs .........
4                     511-BTA04-700T     Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4
2                     534-3517           Fuse Clips and Holders PC FUSE CLIP 5 MM
1                     604-WP7104IT       LED Standard HI EFF RED TRANS marked LED
5   R1,R2,R3,R4,R11   660-CF1/4C681J     1/4Watt Axial Carbon Film Resistors 680ohms 5% marked
4                     660-CF1/4C181J     1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 & R8
2                     660-CF1/4C104J     1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10,
4                     859-MOC3023        Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4
4                     571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                                         also marked U1, U2, U3 and U4
5                     571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
Additions for the SSRneon-G2-LED:
1      504-xxxxx          5mm x 20mm Medium Time Delay Fuses 125VAC 5A Med Time Delay
1      504-xxxxx          5mm x 20mm Medium Time Delay Fuses 125VAC 6A Med Time Delay
1      504-xxxxx          5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay
240VAC Operation
FireGod
Here is a picture of a completed SSRneon-G2-LED:
This PCB has a different terminal block ------------------------------------>
Wiring The SSRneon
 Controller Output Pinout
Original SSRneon
