Simple Renard 32 Combo
Simple Renard 32 Combo - 32 Channel Controller
What is the Simple Renard 32 Combo?
The Simple Renard 32 combo is a low cost 32 channel controller designed to drive either ACSSRs or DCSSRs which switch their loads close to the item being controlled. Unlike other Renard designs like the Renard 64XC, the Simple Renard 32 Combo makes use of a different PIC, the PIC18F4520. This PIC allows 32 chanels per PIC to be controlled compared to the usual 8 channels per PIC (16F688) used in most Renard designs. This allows a smaller board and lower total cost.
The Simple Renard 32 Combo controller is used to control loads in a "star" type system. This means, that the main controller stays in a central location while the SSRs are on the tips of the "spokes". The real savings in this layout is in the power cables. Most of the channel power cables are very short. This system is very good for widely spaced display items with small groups of channels in one area like mini-trees.
The outputs of the Simple Renard 32 Combo are designed to be connected to SSRs which switch the actual loads. The Simple Renard 32 Combo can control DCSSrs like WJohn's DC SSR or Labrat's DCSSR Version 2.4. The Simple Renard 32 Combo can also control ACSSrs like Chris and John's SSRez or Dave's SSRneon
The board requires a good 9-12vac external power supply. An on board voltage regulator provides the necessary power for the PIC and transistors on the pcb.
The board was designed in the Fall of 2010 by mactayl and tstraub, and based on original concepts by p.short, p.rogers.
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Simple Renard RGB+W uses a similar architecture for the logic portions of the board as the RenardSS series of boards. Sequence information is passed from a PC running Vixen or other sequencing program via an RS-485 interface. The RS485 chip receives this information and turn into standard TTL logic levels that the PIC can understand. The PIC reads in the data and if it determines that the information corresponds to itself, it updates the dimming levels of all 32 channels. It removes this information from the stream and feeds the rest out to the RS485 chip which translates it to RS-485 levels for the next controller in the line. It is important to realize that the information is removed from the stream and that the resultant leftover stream will have all of the data offset by the 32 channels of information used by the Simple Renard RGB+W. For example, if you have two Simple Renard RGB+W, on Vixen you would configure a single Renard plug-in with 64 channels. The first SImple Renard RGB+W consumes the first 32 channels of information leaving only 32 channels on it's outputs. The second Renard RGB+W will see this incoming data as controller #1 again and assume the data is for it. This is very much different than standard hard/soft-coded DMX or LOR devices that use a set address yet still pass on the entire stream to the next controller on the line.
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Version v.1b is currently the most recent version of the Simple Renard RGB+W in production.
Simple Renard 32 Combo Parts
| P1 | Fixed Terminal Blocks 5.08MM VERTICAL 2P wire protector | 571-7969492 | 1 |
| BR1 | 4 pin Bridge rectifier 1amp dip | 625-DF02MA-E3 | 1 |
| C1 | 470uf 25V Electrolytic | 647-UVZ1E471MPD | 1 |
| C2 | 220uf 25V Electrolytic | 647-UVZ1E221MPD | 1 |
| D1 | Zener Diodes 4.3 Volt 0.5 Watt) | 78-1N5229B | 1 |
| D2 | Zener Diodes 9.1 Volt 0.5 Watt) | 78-1N5239B | 1 |
| IC2 | RS-485 Interface IC LP Diff Pairs | 595-SN65LBC179P | 1 |
| IC3 | H11AA1 Zero Cross | 782-H11AA1 | 1 |
| IC4 | Linear Regulators - Standard 1A Pos Vol Reg | 512-LM7805CT | 1 |
| IC1 | Microcontrollers (MCU) 32KB 1536 RAM 36I/O | 579-PIC18F4520-I/P | 1 |
| JP1 XBee header | Headers & Wire Housings FLAT HEADER 5P Straight Post tin | 571-640452-5 | 1 |
| Shunt for XBheader and PIC bypass | Headers & Wire Housings Mini Shunt .177" height | 737-MSC-G | 2 |
| R1,R2,R8,R9,R10 | Carbon Film Resistors - Through Hole 1.0Kohms 0.05 | 291-1k-RC | 5 |
| R3,R5 | Carbon Film Resistors - Through Hole 330ohms 5% | 291-330-RC | 2 |
| R6 | Carbon Film Resistors - Through Hole 10Kohms 5% | 291-10k-RC | 1 |
| R7 | Carbon Film Resistors - Through Hole 120ohms 0.05 | 291-120-RC | 1 |
| R11,R12 | Carbon Film Resistors - Through Hole 27Kohms 5% | 291-27k-RC | 2 |
| IC & Component Sockets 8P DUAL WIPE DIPSKT | 517-4808-3004-CP | 1 | |
| IC & Component Sockets 6P DUAL WIPE DIPSKT | 571-1-390261-1 | 1 | |
| Wallwart 9-12 volts AC only | 507-XT1220 | 1 |
Housing
The Simple Renard 32 Combo was designed to fit in the CG-500 Demarcation Enclosure available from numerous vendors including www.wlcventures.com
- Install the resistors:
- Install the capacitors:
- Install the 47uf Electrolytic Capacitors at locations C1,C2. The capacitors are polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole marked with a +.
- Install the IC sockets:
- Install the diodes:
- Install the transistors:
- Install the headers:
- Install the 6 pin header at location ICSP (PIC programing header). The short side of the header strip goes into the board.
- Install the jumper shunts:
- Install the ICs:
Programming the PIC
Final Testing
THIS SECTION IS UNDER CONSTRUCTION. IT IS NOT CORRECT, PLEASE CHECK BACK IN A FEW DAYS... The Simple Renard RGB+W has three diagnostic LEDs.
Mounting in Housing
Jumper Settings / Headers
JP1 XBee Header
Pin Layout
1 = +5VDC
2 = N/C
3 = GND
4 = RX from 485 chip
5 = RX in to PIC
JP2 PIC Bypass
This header is currently unused. The default position is a jumper across pins 2/3.
Pin Layout
1 = Data In From RS485 IC
2 = Data Out to RS485 IC
3 = Data Out from PIC
JP3 ICSP
Pin Layout
Pin 1 = MCLR
Pin 2 = +5 volts
Pin 3 = GND
Pin 4 = PGD
Pin 5 = PGC
Pin 6 = PGM/RB5
Data
J1 is the data input to the Simple Renard 32 Combo
J2 is the data output from the Simple Renard 32 Combo
Outputs
The outputs of the Simple Renard 32 Combo is connected via straight thru Cat5 cables to SSRs.
J3 is Output channels 1-4
J4 is Output channels 5-8
J5 is Output channels 9-12
J6 is Output channels 13-16
J7 is Output channels 17-20
J8 is Output channels 21-24
J9 is Output channels 25-28
J10 is Output channels 29-32
Pin 1 - +5vdc Pin 2 - First Channel Output Pin 3 - not connected Pin 4 - Second Channel Output Pin 5 - not connected Pin 6 - Third Channel Output Pin 7 - Ground Pin 8 - Fourth Channel Output
Power
The Simple Renard 32 Combo makes use of a different PIC then the usual PIC found in most Renard devices. The Simple Renard 32Combo does not use the default Renard firm. You must make use of the special firmware listed below to program your Simple Renard 32 Combo. The Simple Renard 32 Combo firmware only runs Renard protocol. A DMX version is not yet available.
The Simple Renard RB+W has one version of the software available.
- There is one version of the software that makes use of the full 32 channel.
You must modify the firmware in the .inc file to match the correct baud rate of your data network. The default baud rate is 56K.
You must modify the firmware in the .inc file if you want to use a different start address for the device. The default address is 1.
Downloads
PCB
Design Options
Interest thread
Thread 1
Thread 2
