Simple Sound to Servo
The Simple sound to servo is an inexpensive controller based on the Scary Terry sound to servo circuit found here http://www.scary-terry.com/audioservo/audioservo.htm This circuit takes an audio source such as an MP3 player and outputs a signal to a hobby servo to move the jaw to the sound on talking props.
Adjustments
Gain: The gain adjustment is used to control the gain of the amplifier to match the controller to your source audio
Threshold: The threshold adjustment is used to calibrate the circuit and set the point of sound or no sound
Max Adj: The max adjust is used to set the maximum servo position when sound is present. You can think of this like a high limit switch
Min Adj: The min adjust is used to set the minimum servo position when sound is not present. You can think of this like a low limit switch.
Capacitor Select: There are 3 capacitors of different values to chose from. The higher the value of the capacitor the more smooth the jaw will move. If you want a more jerky action enable a lower value capacitor or no capacitor at all. The capacitors are arranged lowest to highest value from left to right. Capacitors are enabled by placing a shunt on the jumpers JP4,JP5,JP6 directly above the capacitors.
L/R Select: If you want the board to "Listen" only to the left or right channel of audio install a shunt on either the left or right jumper. If you want it to "listen" to both channels install shunts on both jumpers.
Connections
Setup
Description of operation
From the Scary Terry website
Jeff Stevens solution
THE ASSEMBLY INSTRUCTIONS ARE A WORK IN PROGRESS, PLEAE CHECK BACK IN A FEW DAYS WHEN IT IS FINALLY CORRECT
 - Install the resistors:
- 220K OHM Resistor R9 The resistor is not polarized, so it can go either way.
 - 1K OHM Resistor R1 The resistor is not polarized, so it can go either way.
 - 47K OHM Resistor R2,R4 The resistor is not polarized, so it can go either way.
 - 10K OHM Resistor R5,R12,R15,R20 The resistor is not polarized, so it can go either way.
 - 2.2K OHM Resistor R14 The resistor is not polarized, so it can go either way.
 - 470 OHM Resistor R8 The resistor is not polarized, so it can go either way.
 - 4.7K OHM Resistor R4,R11 The resistor is not polarized, so it can go either way.
 - Install adjustment trimpots:
- 5K OHM Trimpot Resistor R3 The trimpot only fits one way, with the two legs towards the top of the board.
 - 1K OHM Trimpot Resistor R6 The trimpot only fits one way, with the two legs towards the top of the board.
 - 50K OHM Trimpot Resistor R10,R22 The trimpot only fits one way, with the two legs towards the top of the board.
 - Install 1N914 Diode D1 The diode is polarized and it can only go one way.
 - Install IC Sockets:
- 14 pin IC Socket IC2 The notch on the socket should face the left side of the board.
 - 8 pin IC Socket Ic1, IC3 The notch on the socket should face the left side of the board.
 - Install 2N3904 Transistor Q1 The flat side of the transistor should face the left side of the board.
 - Install Capacitors:
- 2.2uF Electrolytic Capacitor 5x11mm C5 The capacitor is polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole towards the top side of the board.
 - 4.7uF Electrolytic Capacitor 5x11mm C2 The capacitor is polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole towards the top side of the board.
 - 10uF Electrolytic Capacitor 5x11mm C7 The capacitor is polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole towards the top side of the board.
 - 100nF (0.1uF) Mylar Film Capacitor C1,C3,C6,C11 The capacitor is not polarized, so it can go either way.
 - 10nF (0.01uF) Mylar Film Capacitors C4 The capacitor is not polarized, so it can go either way.
 - Install LED 3mm Red D2 The LED is polarized. There is a flat side (cathode) has a short lead and it faces towards the left side of the board.
 - Install jumpers:
- 40 Pin 2.54 mm Single Row Pin Header Strip JP1,JP2,JP3,JP4,JP5,JP6 The short side of the jumper strip goes into the board.
 - Install Screw connectors:
- Screw Terminal Block 3 Positions X3 The side where the wires enter under the screw should face the bottom of the board.
 - Screw Terminal Block 2 Positions X2 The side where the wires enter under the screw should face the bottom of the board.
 - Install ICs:
- LM1458N IC1 The notch on the IC should face the left side of the board.
 - CD4066 IC2 The notch on the IC should face the left side of the board.
 - NE555 IC3 The notch on the IC should face the left side of the board.
Congratulations, you have just fnished building the Simple Sound to Servo.
Here is a schematic diagram in pdf format File:Simple Sound to Servo sch.pdf
Board
All parts were sourced from Tayda Electronics 1 BOM will populate 2 Simple Sound to Servo Boards. The BOM is a double order because just one does not meet the $5 minimum order. You will also have a few left over resistors due to the fact that Tayda requires minimum of 10 each value. The only part that I have not tested is the 3.5mm audio Jack. This jack was an after though and is meant to be mounted as a pass thru connector on your enclosure that way you don't need to open the enclosure to plug your audio cable in.
Tayda Electronics
| Part | Location | Qty | Part # | Link |
| 220K OHM 1/4W 5% Carbon Film Resistor | R9 | 10 | A-2110 | Link |
| 100nF 0.1uF 100V 5% Mylar Film Capacitor | C1,C3,C6,C11 | 8 | A-4110 | Link |
| 1K OHM 1/4W 5% Carbon Film Resistor | R1 | 10 | A-2123 | Link |
| 47K OHM 1/4W 5% Carbon Film Resistor | R2,R4 | 10 | A-2066 | Link |
| 5K OHM Trimpot Variable Resistor 6mm | R3 | 2 | A-2513 | Link |
| 1K OHM Trimpot Variable Resistor 6mm | R6 | 2 | A-2509 | Link |
| 10K OHM 1/4W 5% Carbon Film Resistor | R5,R12,R15,R20 | 20 | A-2115 | Link |
| 1N914 Small Signal Diode 200mA 100V | D1 | 2 | A-615 | Link |
| LM1458N LM1458 1458 IC DUAL OPERATIONAL AMPLIFIER | IC1 | 2 | A-286 | Link |
| 10uF 25V105C Radial Electrolytic Capacitor 5x11mm | C7 | 2 | A-4534 | Link |
| 2.2K OHM 1/4W 5% Carbon Film Resistor | R14 | 10 | A-2087 | Link |
| CD4066 4066 IC CMOS QUAD BILATERAL SWITCH | IC2 | 2 | A-555 | Link |
| 470 OHM 1/4W 5% Carbon Film Resistor | R8 | 10 | A-2049 | Link |
| 4.7K 4K7 OHM 1/4W 5% Carbon Film Resistor | R4,R11 | 10 | A-2027 | Link |
| 50K OHM Trimpot Variable Resistor 6mm | R10,R22 | 4 | A-2500 | Link |
| 10nF 0.01uF 100V 5% Mylar Film Capacitors | C4 | 2 | A-4106 | Link |
| NE555 IC 555 Timer DIP-8 | IC3 | 2 | A-249 | Link |
| 2.2uF 50V 105C Radial Electrolytic Capacitor 5x11mm | C5 | 2 | A-4532 | Link |
| 4.7uF 16V 105C Radial Electrolytic Capacitor 5x11mm | C2 | 2 | A-4529 | Link |
| 2N3904 NPN General Propose Transistor | Q1 | 2 | A-111 | Link |
| LED 3mm Red | D2, | 2 | A-261 | Link |
| 40 Pin 2.54 mm Single Row Pin Header Strip | JP1,JP2,JP3,JP4,JP5,JP6 | 1 | A-197 | Link |
| DG301 Screw Terminal Block 3 Positions 5mm | X3 | 2 | A-669 | Link |
| DG301 Screw Terminal Block 2 Positions 5mm | X2 | 2 | A-668 | Link |
| 14 pin DIP IC Socket Adaptor Solder Type | 2 | A-004 | Link | |
| 8 pin DIP IC Socket Adaptor Solder Type | 4 | A-001 | Link | |
| 3.5mm Stereo Enclosed Socket | 2 | A-865 | Link |
Total cost for 2 BOMs $5.01
You will also need a few shunts. Tayda does not carry them or at least I could not find them. I just grab them out of old disc drives and motherboards.
Housing
