SSRneon
Safety Features
Order your own boards
Home Etch
Fuse Rating
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Bowf, SSRoz, SSRez.
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
Here is a picture of a completed SSRneon:
This PCB has a different terminal block ------------------------------------>
Wiring The SSRneon
The following image shows how to connect wires to the SSRneon.
The pin-out for the RJ-45 cable is the same for all of the Sean Bowf derivative SSRs:
 Controller Output Pinout
Original SSRneon
