RGB / PIXEL CONTROLLERS / Extenders
Feature Comparisons
| RITA | HD-714 | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
| RITA | HD-712 | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
| RITA | PX24506 | Yes | 12V - 24V | 3 | 3A | 9A | DMX | $22.32 | $7.44 |
| Unknown | L12-DMXMODEL-3CH-LV | Yes | 12V | 3 | 4A | 12A | DMX | $6.21 | $2.09 |
| wjohn | REN64 | No | 9-35vdc | 64 | 2A per Chn | up to 7A per SSR | RS232, DMX | $48.00 | $1.00 |
| Renard | Renard 48LSD | No | 9-24vdc | 48 | 600mA | RS232, DMX | $48.00 | $1.00 |
PIXAD8
Protocol E1.31
The ECG-PIXAD8 is an interface adapter that conditions and distributes the signals from the ECG-M32MX to 8 different pixel strings using serial pixel protocols (SPI and Manchester Encoded). The ECG-PIXAD8 includes two separate power buses with bus fuse protection and individual string fuse protection. Each bus is supplied power via high current screw terminals and the strings are provided power and signal through a pluggable terminal strip for each string. The software controls the round-robin sharing of two dedicated SPI channels. Each channel is responsible for serving one group of four strings.
More details at http://www.j1sys.com/ecg-pixad8/
ECG-P12R
The ECG-P12R is a pair of assembled and tested boards. The boards are the P12R controller and a P12x Panel board. The boards are split into two functions to allow flexibility in packaging and to allow the P12x Panel board to be made with 3oz copper to deliver the higher amperage needed to distribute power across multiple strings.
The ECG-P12R is designed to provide the digitial level signals for 12 different pixel strings using serial pixel protocols (SPI and Manchester Encoded). The software controls the round robin sharing of three dedicated SPI channels. Each channel is responsible for serving one group of four strings.
More Details at http://www.j1sys.com/ecg-p12r/
ECG-PPX
E680/681
E680 information http://sandevices.com/E680info.html
E681 information http://sandevices.com/E681info.html
TP3244 Pixel Driver
- Controlled through: DMX
RPM WS2801 to DMX Pixel Bridge
T3: DMX512 - SPI Bridge
E2: Ethernet - SPI Bridge
E16-II Controllers
The E16-II controllers are Stellascapes flagship controllers for SPI based RGB Led fixtures. Based on Stellascapes successful E16-I, the E16-II brings a number of improved features, and and increased range of ready to use configurations. All variants share a number of key features;
Art-net II, or Streaming ACN ( E1.31 ) input protocols - DMX over IP.
10/100 Megabit Ethernet
16 output strings, each individually configurable for addressing
Easy to use web based GUI for control
On Board Single RGB LED for system testing without the need to have attached string
16 Character LCD Display for diagnostics and identification information.
E16 - Commercial
The E16-II Commercial controller is a ready to install system designed for permanent or low movement installations, such as permanent theme park installations, or holiday lighting. Enclosed in a high impact, UV resistant case the E16-Commerical includes an integrated mains power supply ( 110-250VAC 50/60Hz ), providing 320W of power, sufficient to fully power 672 RGB pixels. Waterproof Cable glands provide an mechanism for cable entry for UTP and Mains. Splash proof venting systems are used to duct air in and out of the system for active cooling. 16 400mm "tails" with waterproof screw up connectors are provided for interconnection to the strings. Each String is individually fused to provide protection in the event of a failure or breakage.
E16-Bare
The E16-II is available as a set of "bare-board" assemblies. The boards includes the microprocessor and associated circuitry, software, ethernet interconnectivity and buffered outputs. Bring your own case, power supply, output connectors. Perfect for the do-it-yourselfer , or where the system needs to be build into something where the commercial or Pro systems just won't work. Note Stellascapes does not provide a PCB only option.
