SSRneon
Safety Features
1. Dual Neon bulbs that indicat the presence of AC Voltage !
Order your own boards
Home Etch
Fuse Rating
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Bowf, SSRoz, SSRez.
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
Here is a picture of a completed SSRneon:
This PCB has a different terminal block ------------------------------------> for the AC input line then what is shown in the BOM. This is simply a personal preference.
Wiring The SSRneon
The following image shows how to connect wires to the SSRneon.
If all is well, you should see both neon bulbs glowing signaling AC voltage is present and flowing through the fuse. The LED should also be lit to indicate that 5 volts DC is being supplied by the lighting controller.
Original SSRneon
