Vastelec FM02
Pictures of FM02's in enclosures
- Here are various ways that folks have built and deployed their FM02's
http://www.doityourselfchristmas.com/wiki/index.php?title=FM02_Gallery
Do you have a HUM ?
Audio
Schematic and PCB layout
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Additional Modifications
PART15:
