Vastelec FM02
Revision as of 03:34, 7 October 2011 by Ukewarrior (talk | contribs) (Audio)
FM-02
click on the picture for a larger version
- Power. A regulated 12v DC power supply is needed. 100ma is enough current.
About VAST Electronics
Vendor's Website
Data Sheet
DO NOT apply anything GREATER then REGULATED 9V-16V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit (Part number:PS-SP12113). These are about $5 online.
When you connect power to the FM02 it is VERY important that you get your positive(+) and your negative(-) correct. If you hook up the power incorrectly, you can easily damage/ruin the unit.
Do you have a HUM ?
Some Beads split in half, some don't !
A Split Ferrite bead
A multi wrap Ferrite bead
There are some good pictures in the wiki-pedia-: http://en.wikipedia.org/wiki/Ferrite_bead
Audio
3.5mm stereo plug
Detailed Board Dimensions
board dims
board dims
board dims 2
board dims 2
Antenna
smatobnc
smatobnc
You will need to buy or make an antenna. There are MANY different designs for antennas. A large number of DIYers have made a type of antenna known as a dipole. This is an easy to make antenna that will serve almost anyone's needs. Here is a link to a pdf with instructions to make your own: How to Make a Dipole Antenna
What Frequency to Use
http://www.radio-locator.com/
Where can I get one of these wonderful FM transmitters ?
