Ren48LSD
Ren48LSD Construction Manual
What is the Ren48LSD?
The strips require up to 360mA per output (18 LEDs x 20mA) so I used an NPN bipolar transistor to drive them. The transistors support up to 600mA so there's plenty of headroom left. The transistors are fairly cheap so it makes for a simple, inexpensive solution. The controller design used the Ren24SS as a base, using the same PIC, clocking and serial interface configuration but expanded to 6 PICs to support 48 channels or driving up to 12 strips per board. Because of this, the controller supports standard Renard protocol FW using RS-232/485 as well as the DMX version. The board requires either a 5vdc well regulated supply or a good 9- 12vdc supply. The input supply also drives the LED strips.
Ren48LSD Parts
| Mouser BOM | ||
| 579-PIC16F688-I/P | Microcontrollers (MCU) 7KB 256 RAM 12 I/O | 6 |
| 571-1-390261-3 | IC & Component Sockets 14P ECONOMY TIN | 6 |
| 863-MPS2222AG | Bipolar Transistors 600mA 75V NPN | 48 |
| 511-L7805CV | Linear Regulators - Standard 5.0V 1.0A Positive | 1 |
| 604-WP7104IT | Standard LED - Through Hole HI EFF RED TRANS | 1 |
| 80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% | 10 |
| 299-1K-RC | Carbon Film Resistors 1.0Kohms | 2 |
| 299-470-RC | Carbon Film Resistors 470ohms | 48 |
| 299-10K-RC | Carbon Film Resistors 10Kohms | 6 |
| 571-5520251-4 | Telecom & Ethernet Connectors 8/8 SIDE ENTRY | 14 |
| 571-7969492 | Terminal Blocks 5.08MM VERTICAL 2P wire protector | 2 |
Building the Ren48LSD
- Some find it easier to install the two decoupling capacitors near the RS485 chips at this point - jump ahead one picture to see where they go - otherwise install them after the sockets
 - Install the ten decoupling capacitors near the IC sockets, oscillator and regulator
- Install the two 2-pin shunt jumpers (note picture shows only one installed)
 - Install the 5v regulator (OPTIONAL) - the back goes towards the edge of the board
 - Install the large capacitor – note correct orientation
- If you are not using the 5v regulator then you need to install a jumper across the input/output of where the regulator goes. A 1/2W resistor lead is good for this but any 18-20 gauge wire is fine.
- Install the fourteen RJ45 jacks – note that top-entry jacks can be subsituted
 - Mount the 5v regulator heat sink if you installed the regulator – use a small amount of heat sink compound
Initial Testing
Renard Protocol
Make the following changes:
Renard-DMX Protocol
#define DMX_START_ADDRESS 1
Final Testing
- Common +DC
 - Red Ground
 - Common +DC
 - Blue Ground
 - Common +DC
 - Green Ground
 - Common +DC
 - White Ground
Q1: Can this use 24vdc?
A1: Yes it can but it will require a different regulator (actually a DC-DC switching converter). This applises to all voltages from 12-24vdc actually. Please review this File:Ren48LSD-Regulator-Change.pdf for options regarding the changes required.
Q2: What if I only have 6 strips?
A2: Well - you're in luck! Next to PIC #3 and PIC #6 is a via hole that will bypass PICs #4 - #6 if you install a wire between them. Note that this is only necessary if you are planning to daisy-chain another board from this one. This effectively makes this a Ren24LSD. If you are not going to daisy-chain another board, you can leave it off as well as the RS-485 output chip. Personally, I think this is false economy since you'll have to dig the parts up if you change your mind and want to run a board off this one. In either case, you certainly save time and money by not installing the PICs, sockets, transistors, resistors and output connectors for strips 7-12 if you don't have them.
Q3: What the heck is that "GAB DMX-THRU" connector for?
A3: This was an attempt to support DMX-THRU so that you can run additional DMX devices from an external RJ45 or XLR connector. "GAB" stands for "Ground", "Data-A" and "Data-B" for the RS-485 interface for DMX. This has not been tested at all yet so it may or may not work at this time. If you do try it and it works, please let me know and we can udpate this entry to show it works OK.
Q4: Can I use standard DIY SSRs with the Ren48LSD?
A4: Maybe - but with the following caveats:
<PDF Version removed as it was downlevel>
