Electronics Hardware
Revision as of 15:22, 16 September 2010 by Dmcole (talk | contribs) (Ledtriks: Made all spellings of LedTriks, Triks-C and PIX-C consistent; fixed some wording.)
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
Firegod
  • Documentation: Firegod
Renard
  • Documentation: Renard
Lynx
Helix
  • Documentation: Helix
LedTriks
Triks-C
This is a an add on controller/processor for the LedTriks. The TRIKS-C uses an ATMEL processor to take a LedTriks file and send it out to the LedTriks Controller, via the serial port.
PIX-C
  • Documentation: PIX-C
JEC Pixel Displays
  • Controlled through: DMX
rgbLED
Digital Input/Output Cards
