Renard 64XC
- The Renard 64 is a PIC microcontroller based Christmas light controller designed to be used with external Solid State Relays or SSRs. The board design is based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed here. Generic information pertaining to current Renard designs (including maximum channel count) can be found on the Renard wiki page.
The Board
Circuit Diagram
- Key circuit components
- Connectors
- J3 – RS485 outgoing data
- Connectors
- IC Chips
 - U7-U14 – PIC16F688 Microcontrollers
- IC Chips
- Resistors
- Resistors
- LEDs
- LEDs
- When U6 is programmed with the Diagnostic Firmware:
- Channel 2 - will blink ON/OFF to indicate that the PIC is operating correctly.
 - Channel 5 - will blink ON/OFF to indicate that the Zero Cross signal is getting to the PIC correctly.
 - Channel 6 - will be ON whenever the PIC is receiving data correctly.
 - Channel 7 - will only be ON when the PIC has identified a Framing Error while receiving data.
 - Channel 8 - will only be ON when the PIC has identified an Overrun Error while receiving data.
- Other Components
- Other Components
- Jumpers
- Jumpers
- Test Points
 - GND – Ground
 - ZC – Zero Cross signal
- Test Points
Powering the Renard 64
DC power:
AC Power:
- If you do not have 120VAC power, then you may have a larger challenge. A cost effective transformer from 220VAC to 6.3VAC has not been located. There are options but you should get some expert assistance from forums members. Careful selection of resistor replacements with special care to the overall maximum input voltage is required and each case is special.
AC Power Handling Capability
Hooking Up the Renard 64
Data Connections
Data Cables
- Data cable for Renard 65 board hookup using a RS232->RS485 converter
RS485(-) Signal to RJ45-pin 4 RS485(+) Signal to RJ45-pin 5
- Data cable for Renard 64 board hookup in a DMX environment
- Generally only a regular straight-thru CAT5 cable is required to connect Renard SS boards to other Renard boards. For the few exceptions (ie Ren24 V2.5), check the wiki page for those boards to see what their unique requirements are.
Cable Lengths
- Data cables connecting the Renard SS boards directly to a computer COMM port should not be longer than 50 feet according to the RS-232 standard. This distance can also be greatly reduced by using poor quality cables. However, this distance can be increased buy using high quality, low impedance cables.
- The above image shows how Renard boards in general can be daisy chained together. Renard SS8 boards are used in the image just as an example of how all Renard SS boards can be connected together.
Computer Setup
- VIXEN Settings
- Protocol Version: 1
 - Parity: None
 - Data bits: 8
 - Stop bits: One
- If you are unsure that you have built your hardware correctly, you should follow the procedures contained in the Renard SS24 Beginners Setup Guide. These procedures will guide you through the steps to help setup the hardware for the first time.
- If you encounter any problems with your Renard SS24, you can go to the Troubleshooting Guide The Renard SS24. The troubleshooting guide contains a methodical process to try to isolate problems/malfunctions and gives suggestions of what to do to fix them.
