Ren-W BOM and Construction
 - 1 -- XBee Wireless RF modules Mouser# 888-XBP24-AWI-001 (pro version with 1" mini-whip antenna)
 - 1 -- Ren-W circuit board (etch your own in the true DIYC spirit, or contact dirknerkle for pre-made boards)
PCB Parts Layout
- The only important difference between the standard board and the SMA board is the orientation of the XBee modules. The standard board has the modules pointing upward; the SMA version has them pointing downward to allow for the long SMA antenna connector. Pay careful attention to the orientation of the XBee when plugging it into the board. If you have the standard board, plugging in an XBee module with an SMA connector upside-down will NOT WORK. Likewise, plugging in an XBee with a 1" whip the wrong way on an SMA board won't work, either.
Construction Step-by-step
- The construction steps are identical for both the standard and SMA version of the board. Caution - the pins on these headers are quite tiny and require very little solder. Too much solder may flow down and fill the pin hole in the header itself and prevent plugging in the XBee later on.
- 4. OPTIONAL: Solder non-polarized capacitors C4, C5 and C6. Like C1 and C2, if electrolytic capacitors are used, observe the + polarity markings on the board. (Note: C4, C5 and C6 do a lot to clean up the RS-232 signal the Ren-W provides to the Renard controller, and these are essential if connecting the Ren-W to a Ren-C/595 or Ren-C/Grinch. However, in testing, C4, C5 and C6 were proven to be unnecessary when using the Ren-W with Renard SS controllers.)
- 7.	Solder RJ45 jacks J1, J2
- 11. Solder the 3.3v voltage regulator U1. The heat sink side faces toward JP2 (top). The need for an additional heat sink is highly unlikely as the supply voltage is only 5vdc. At this point, applying power to the board should light the LED (if installed) and the voltage test points in the middle of the board should register the proper voltages. Disconnect power before continuing with the next step.
Powering the Ren-W board
- The Ren-W draws its +5vdc power from the Renard SS board via the left pin of the Renard’s JP3 header; the ground power connection is made when the Ren-W is connected to either of the SS controller's RJ45 jacks. A nifty solution that retains the SS controller’s ability to use the diagnostic LEDs is to solder each end of a single strand of cat5 wire to an open jumper shunt (see photo above) and simply plug the shunts into the JP3 headers on both the SS controller and the Ren-W. Alternately, you may wish to make your own power cable using two female SL connectors; use a small piece of shrink tubing around the connector for insulation safety. (Both pins on the Ren-W’s JP3 header are +5vdc; both JP4 pins are ground connections.)
- With Frank Kostyun's Ren24 ver 3.3, +5vdc can be taken at TP5 (test point 5). You may drill a small hole in the pad if you wish to solder-in a single pin header.
- With Wjohn's Ren64 (version XC5) there is a small, unmarked +5vdc test point immediately below pin 8 of U5 (the rightmost ST485BN chip) and just left of R14. Solder-in a single header pin if you like.
- With Wjohn's Ren-C, +5vdc can be taken from the header pin immediately to the left of the Q1 transistor. The pin is marked VCC. Another +5vd VCC location is the 2nd from the top pin of the 6-pin JP6 programming header. Either location is fine.
Other Voltage Test Points
