Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
 - Documentation: Firegod
Renard
 - Documentation: Renard
Lynx
- Controlled through: DMX
Helix
 - Documentation: Helix
Ledtriks
Triks-C
- Controlled through: Serial port or standalone
This is a an add on controller/process for the Ledtricks. One of the problems with the original LEDTRIKS design was the load placed on the PC to chunk the data out the parallel port. The TRIKS-C uses a ATMEL process to take a LEDSTRIKS file and send it out to the LEDTRIKS Controller, via the serial prot.
JEC Pixel Displays
rgbLED
			Renard SS 8
			Renard SS 16
			Renard SS 24
			RPM USB to DMX Adaptor
Digital Input/Output Cards
