Ren-W BOM and Construction
 - 5 -- 1 uf capacitors (non-polarized - C1, C2, C4, C5, C6) Mouser# 810-FK24Y5V1H105Z (Note: 1 uf electrolytic capacitors may be substituted if you wish; polarity markings are provided on the board as a convenience if you use the electrolytics.)
Step-by-step Construction
 - 2. Solder the 16-pin DIP socket into the MAX232 location (skip if no socket is used and the MAX232 is to be soldered directly to the Ren-W board) .
 - 3. Solder capacitors C1 and C2. (Note: Either non-polarized or electrolytic types are okay. No polarity concerns for the non-polarized capacitors. However, if electrolytic capacitors are used, observe the + polarity markings on the board.)
 - 4. OPTIONAL: Solder non-polarized capacitors C4, C5 and C6. Like C1 and C2, if electrolytic capacitors are used, observe the + polarity markings on the board. (Note: C4, C5 and C6 do a lot to clean up the RS-232 signal the Ren-W provides to the Renard controller, and these are essential if connecting the Ren-W to a Ren-C/595 or Ren-C/Grinch. However, in testing, C4, C5 and C6 were unnecessary when using the Renard SS controllers.)
- 5. Solder electrolytic capacitor C3. Note the polarity: the + side into the square pad (top) closer to jack J2.
 - 7.	Solder RJ45 jacks J1, J2
 - 12. Install the MAX232 and XBee module(s) in their respective sockets. Note the position of pin 1.
 - 13. Install optional jumper shunt at JP6 if necessary. This bypasses the R1 resistor (33 ohms) and allows a weaker signal through to the XBee radio in transmit mode.
 - 14. Install optional jumper shunt at JP5 if necessary. This makes the Ren-W into an E-Mode repeater where a single XBee module in the TX position serves as both the receiver and re-transmitter.
Powering the Ren-W board
- The Ren-W draws its +5vdc power from the Renard SS board via the left pin of the Renard’s JP3 header; the ground power connection is made when the Ren-W is connected to either of the SS controller's RJ45 jacks. A nifty solution that retains the SS controller’s ability to use the diagnostic LEDs is to solder each end of a single strand of cat5 wire to an open jumper shunt (see photo to the right) and simply plug the shunts into the JP3 headers on both the SS controller and the Ren-W. Alternately, you may wish to make your own power cable using the two female SL connectors; use a small piece of shrink tubing around the connector for insulation safety. (Both pins on the Ren-W’s JP3 header are +5vdc; both JP4 pins are ground connections.)
 - Ren-W as a standard repeater: connect J1 to J1 and J2 to J2 on the SS.
 - Ren-W as an E-mode repeater: connect J1 to J1 and J2 to J2 on the SS, add a jumper on the Ren-W’s JP5 and make sure the Ren-W has only a single XBee module plugged into the TX (left) position.
 - If connecting to the RS-IN of a Ren-C, be sure to include at least one balun on the cat5 cable.
Other Voltage Test Points
