Ren-W Troubleshooting
Voltage Measurements: three test points are just below pin 16 of the MAX232 chip/socket:
- Be certain that the following components are mounted on the board properly:
 - The zener diode (D1) has the black stripe on the TOP, next to the JP6 header pins.
 - The 3.3 voltage regulator (U1) has the metal tab facing up, toward the JP2 header pins.
 - The LED (D2) while not shown in this photo, has the cathode (flat side) facing the mounting hole to its right.
 - Resistor R2 (1k ohms) is immediately to the left of the LED. The resistor has no polarity concerns.
- Very few pins of the XBee radio modules are actually used; most are unused and serve only to hold the header pins securely.
 - The solder pads for the XBee headers are very small; accurate and careful soldering is a must to prevent solder bridges. A solder bridge could easily prevent the XBee radio from functioning properly.
- Easy Mistakes to Make
- Plugging the XBee module into the wrong side of the board. Remember:
 - Setting the destination address of an XBee module to the wrong address.
 - Resetting the XBee radio back to the default settings and forgetting to change the baud rate back to the 57,600 that Renard uses.
 - Mounting the Ren-W so the antenna is too close to a transformer on the Renard controller can cause erratic transmission and/or reception behavior.
