Ren-W Troubleshooting
Voltage Measurements: three test points are just below pin 16 of the MAX232 chip/socket:
- Some components have specific mounting requirements:
 - The zener diode (D1) has the black stripe on the TOP, next to the JP6 header pins.
 - The 3.3 voltage regulator (U1) has the metal tab facing up, toward the JP2 header pins.
 - The electrolytic capacitor (C3) has the - strip facing DOWN toward the LED, which means the + side is up toward the J2 jack.
