Assembly Instructions The Renard SS16
Board Assembly
- The following sequence of steps is by no means the only way to Assembly the Renard SS16. It is simply a suggested order of events to achieve the desired goal.
- NOTE: The part numbers referenced in the following instructions are those taken from the Renard SS16 BOM.
Triac Heat Sink
- A simple heat sink can be fabricated from .5"x.5"x.060" (1/16”) angle aluminum available at your local home improvement store. You can use a larger size angle if desired, but you have to keep with the 1/16" thickness A template for the hole pattern can be found here. The triac listed in the BOM has an isolated tab, so no isolators are needed.
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
QTY | REF | NOMENCLATURE |
| 520-TCH1843-X | 1 | U3 | Crystal Clock Oscillator, 18.432 MHz |
| 579-PIC16F688-I/P | 2 | U6, U7 | PIC Microcontroller |
| 571-1-390261-3 | 2 | IC Socket, 14 pin (for U6, U7) | |
| 859-MOC3023 | 16 | M1-M16 | Optoisolator, Triac Driver |
| 571-1-390261-1 | 17 | IC Socket, 6 pin (for U2, M1-M16) | |
| 511-BTA04-700T | 16 | T1-T16 | Triac, 4A 700V |
| 299-680-RC | 17 | R6, R10-R25 | Resistor, Carbon Film 680 ohms 1/8W 5% |
| 291-180-RC | 16 | R26 – R41 | Resistor, Carbon Film 180 ohms 1/4W 5% |
| 625-1N5817-E3 | 4 | D1-D4 | Diode |
| 604-WP7104IT | 2 | FE, OE | LED, 3mm Red |
| 604-WP7104GT | 4 | PWR, HB, ZC, SD | LED, 3mm Green |
| 140-XRL16V2200-RC | 1 | C1 | Radial Electrolytic Capacitor 16V 2200uF 20% |
| 140-XRL16V47-RC | 1 | C2 | Radial Electrolytic Capacitor 16V 47uF 20% |
| 80-C322C104K5R | 2 | C3, C4 | Capacitor, Radial Ceramic 50V 0.1uF |
| 571-2828372 | 16 | Channel Terminals | Terminal Block, 2 Pos 5.08 mm |
| 571-7969492 | 2 | Power Terminals | Terminal Block, 2 Pos 5.08 mm |
| 151-8000 | 3 | Shunt | |
| 504-GMA-10 | 2 | F1, F2 | Fuse, Fast Acting 10A |
| 534-3517 | 4 | Holder, Fuse Clip PCB mount 5mm | |
| 534-3527C | 2 | Cover, Fuse | |
Below is the same parts list as above but it is formatted for direct importing into the Mouser BOM feature. Just copy and paste the list as is.
511-LF50CV|1 532-577102B00|1 782-H11AA1|1 520-TCH1843-X|1 511-ST485BN|2 571-1-390261-2|2 579-PIC16F688-I/P|2 571-1-390261-3|2 859-MOC3023|16 571-1-390261-1|17 511-BTA04-700T|16 291-750-RC|2 291-120-RC|1 299-1K-RC|2 299-27K-RC|3 299-680-RC|17 291-180-RC|16 264-330-RC|1 625-1N5817-E3|4 78-1N5239B|1 78-1N5229B|1 604-WP7104IT|2 604-WP7104GT|4 140-XRL16V2200-RC|1 140-XRL16V47-RC|1 80-C322C104K5R|2 571-2828372|16 571-7969492|2 152-3409|1 571-5556416-1|2 538-22-03-2021|3 151-8000|3 504-GMA-10|2 534-3517|4 534-3527C|2 838-3FS-312|1
