16 Channel Renard with SSR Assembly Instructions
- Assembly Time: 2 hours
 - Skill Level: Medium
Disclaimer
Use of this material is undertaken at the users own risk. We assume no responsibility for any consequences you encounter by using the information here.
Tools
- Bench Soldering Iron
 - Silver Solder
 - Flat cut dykes
 - Desoldering bulb
Build Steps
| Item | Qty | Mouser P/N | Board Loc | Notes |
| 1. Install IC sockets 6 pin | 17 | 571-3902611 | ? | Make sure they are oriented the same way as the silk screen image. |
| 2. Install IC Sockets 8 Pin | 2 | 575-193308 | ? | |
| 3. Install IC Sockets 14 Pin | 2 | 575-199314 | ? | |
| 4. Install Bossman Fuse Holder | 4 | 504-1a3399-10 | Double large holes between the triacs | Make Sure the notch on the fuse holder are oriented so one is on the top and the other on the bottom to properly hold the fuse. |
| Spot for Picture | ||||
