Compatible Serial Adapters
With all of the newer desktop and notebook computers loosing serial ports. most of us are having to resort to adding either a PC serial card or some usb to serial device..
With so many brands that are available there are just too many to test to see which ones that do work and the ones that don't ....
Here is a comprised list of known compatible serial port adapters that will work with the Renard designs. If you know of a known adapter that works with our designs please send wvengineer a private message at the DIYC forums so it can be added to the list...
Known Working devices
PC Card
- StarTech PCI4S550N Value 4-Port 16550 Serial PCI Card (will work up to 115,200 bps) sources for this devive: Tiger Direct
USB to RS232
- Trend Net TU-S9 (will work up to 115,200 bps) sources for this devive: Newegg
USB to RS485
- Hexin HXSP-2108G (will work up to 115,200 bps) sources for this devive Ebay Search - Specs here: Hexin Website
 - PAUB003 USB 2.0 to RS485-RS422 (will work up to 115,200 bps) converter can be found here on Ebay
 - MWE824 USB to 4-Port RS485 Converter (will work up to 115,200 bps) sources for this devive: USconverters
