Serial, RS485
RS-485 is very similar to RS-422 where it is balanced pair communications in order to archive high bit rates over long distances with minimal or no noise introduced into the data.
EIA-485 only specifies electrical characteristics of the driver and the receiver. It does not specify or recommend any data protocol. EIA-485 enables the configuration of inexpensive local networks and multidrop communications links. It offers high data transmission speeds (35 Mbit/s up to 10 m and 100 kbit/s at 1200 m). Since it uses a differential balanced line over twisted pair (like EIA-422), it can span relatively large distances (up to 4000 feet or just over 1200 metres).
| Here is an image showing balanced differential communications where noise that is induced is canceled out be the opposite pair | ![]()  |
Advantages & Disadvantages
Advantages of RS-422 and RS-485:
- Higher data rates up to 10Mbps
 - Longer cable lengths up to 4000 Feet
 - Noise rejection or total noise immunity
 - Any ground loops would not affect data transmission
Disadvantages of RS-422 and RS-485:
- Only one transmitter for most applications
 - More cabling required compared to RS-232
 - Not as common compared to RS-232
