Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
 - Documentation: Firegod
Renard
 - Documentation: Renard
Lynx
- Controlled through: DMX
Ledtriks
 - Documentation: LedTriks Controller Assembly Instructions
LedTriks Wiring Diagram
This is a controller to control low-voltage LED panels, designed by Robert Jordan.  These panels are typically 16 LEDs high by 48 LEDs wide, for a total of 768 LEDs.  Vixen can control up to four panels through one parallel port, and can even display text.
Tricks-c
- Controlled through: Serial port or standalone
 - Documentation: [TBA]
This is a an add on controller/process for the Ledtricks. One of the problems with the original LEDTRIKS design was the load placed on the PC to chunk the data out the parallel port. The TRICKS-C uses a ATMEL process to take a LEDSTRIKS file and send it out to the LEDTRIKS Controller, via the serial prot.
JEC Pixel Displays
rgbLED
TBA
			Renard SS 8
			Renard SS 16
			Renard SS 24
Digital Input/Output Cards
