Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
The overal archecture of the system looka like this:
Renard
 - Documentation: Renard
Lynx
- Controlled through: DMX
Ledtriks
 - Documentation: LedTriks Controller Assembly Instructions
JEC Pixel Displays
rgbLED
TBA
			Lynx (DMX dimmer)
			Inside the Lynx
