ESPixel Stick & ESPixel Pops
![Version V2](/wiki/images/9/95/Pops_tiny.jpg)
![Version V2](/wiki/images/3/30/Pops_board.jpg)
![Version V2](/wiki/images/2/29/Pixel_Pops_Tiny_Picture_2.jpg)
What is a Pixel Stick?
These controllers have two basic characteristics:
Click Here:
Pixel Pops & Tiny
Therefore, if you use the TINY board, you must have some other mechanism in order to program the ESP-01 module.
![small](/wiki/images/6/67/Built_unit_with_quarter_for_scale.jpg)
Order your own boards
If ukewarrior is out of boards, you can order them in groups of 3 from OSHPark: Click here for the Ordering link at OSHPark to order your own boards
Fuse Holder
5A Fuse
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
BOM UPDATE:
DIYC member mattd has done some research and created a BOM with some alternate manufacturers.
![small](/wiki/images/b/b5/Pixel_pops_both.jpg)
Wiring The ESPixel Pops
![small](/wiki/images/5/57/Pixel_pops_tiny_built_by_Steven_Dill.jpg)
![small](/wiki/images/e/e3/Pixel_pops_tiny_with_radio_built_by_Steven_Dill.jpg)
A Key Point Regarding Power
Programming the ESP-01 Module
The ESPixel Pops board can do this, (but not the Tiny)
Upload the firmware
Download the latest Firmware.
Install Java JRE.
