ESPixel Stick & ESPixel Pops
![Version V2](/wiki/images/3/30/Pixel_Pops_Picture_x2.jpg)
From a software perspective, it is an E1.31 sACN (Streaming ACN) pixel controller that connects over a standard (802.11g/n) WiFi network. The firmware is open source and developed in the ESP8266 Arduino environment. It provides a web based configuration front-end and currently supports WS2811 / WS2812 pixels.
This variation was created by Pops Jones (ukewarrior) in order to create a form factor that would fit inside a 1" thin wall PVC tube.
![small](/wiki/images/c/c3/Pixel_Pops_Picture.jpg)
4. The board is small enough to fit inside a 1" thinwall PCB pipe with the board measuring only 24.18x33.32 mm
Order your own boards
Here is a picture of a completed ESPixel Pops: (The fuse cover has been removed)
Updated picture to be added....
Wiring The ESPixel Pops
Controller Output Pinout
![Version G2](/wiki/images/d/d8/Ssrneong2led.jpg)
