7 Steps to Selecting a Controller
Intro/Disclaimer:
- This is not a How-To on how to setup a computerized lighting display. This page does not address (directly) the additional factors required for a lighting display, e.g., SSRs, extension cords, CAT5 cable, board enclosures, or computer hardware.
- This page is intended to provide a new member with a logical sequence of things that they need to consider when deciding which light controller they should build.
- There are probably many views about the order of these steps but it is doubtful that anyone would say that these are the wrong things to consider when deciding on a light controller.
Step 1: Determine the layout of your display
- Knowing how you plan to have your lights distributed will go a long way in helping decide which type of controller to go with. It doesn’t have to be set in stone but have a general idea of how you want things to be setup.
Step 2: Determine if you want to have dimming capability in your display
- The single most important factor in narrowing the field to determine which controller board to go with.
- Non-Dimming controllers/methods
- Olsen 595
- Grinch
The Olsen 595 and Grinch can be made dimmable by adding a Ren-T and Ren-C but if you are starting from scratch there is no point in going that route if you know that you want dimming from the start. - Hill320
- Kit74 relay board
- Direct parallel port to SSR
- Dimming controllers
- Renard8
- Renard16 (Xmus16)
- Lynx
- Renard24
- Renard64
- Lynx Freestyle (in development)
- Firegod
Step 3: Determine which topology you will be using
- How you plan to setup your controllers and SSRs is a huge factor in which controller to use. It is the second most important factor in narrowing the field to determine which controller board to go with.
- Fully Centralized: Controller board and SSRs are setup next to controlling computer (usually in the garage or house).
- Advantages:
- Controller and SSRs protected from the environment/vandals
- Controller and SSRs easily accessible for troubleshooting/repair
- Disadvantages:
- Lots of long extension cords running from hardware to lights
- Cost of long extension cords
- Controller boards favored by this topology
- All controller boards/methods can be used in this topology
- Partially Centralized: Controller board is setup next to controlling computer and the SSRs are distributed outside around the display.
- Advantages:
- Ideal for small clusters of lights in multiple locations
- Controller board protected from the enviroment/vandals
- Less amount of long extension cords required
- SSRs interchangeable, makes troubleshooting/repairs easier
- Disadvantages:
- Lots of CAT5 cable thru-out your display
- SSRs exposed to the enviroment/vandals (requires weatherproof enclosure)
- Controller boards most suitable for this topology
- Olsen 595
- Grinch
- Hill320
- Renard64
- Lynx Freestyle
- Firegod
- Decentralized: Controller boards have SSRs integrated on them and are distributed outside around the display.
- Advantages:
- Ideal for a large cluster of lights in one location
- Less amount of cabling
- Disadvantages:
- Distance from computer to first controller can cause communication problems
- Controller board exposed to the environment/vandals (requires weatherproof enclosure)
- Renard16 (Xmus16)
- Renard24
- Lynx
Step 4: Calculate your estimated channel count
- You need to have a good idea of how many channels you will be needing to control in your display.
- Channel count along with your desired topology drives how many controllers you will need.
*** If you have gotten this far in the process then you should already have your decision narrowed down to just a few controller options. Now would be a good time to do some in-depth research into each of the boards that you are considering. This research will make determining which communication protocol to use much easier. ***
Step 5: Determine how you want your computer to communicate with your controller
- Parallel
- Advantages:
- Cheap. Most computers have a parallel port
- Easy to adapt a printer cable to work with controller
- High channel count capable with Olsen 595 and Grinch
- Disadvantages:
- Distance from computer to first controller limited
- Voltage on parallel port signals vary greatly from computer to computer
- In general, only good for On/Off light control
- Usually on 1 parallel port per computer
- Controller boards using parallel
- Olsen 595
- Grinch
- Hill320
- Kit74 relay board
- Direct connect to SSR
- Serial
- Advantages:
- Cheap. Most computers have a serial port
- Easy to add more serial ports (USB=>RS232 adapters)
- Moderate distance from computer to first controller (a cheap RS232=>RS485 adapter increases distance to over 500 feet for Renard's)
- Disadvantages:
- Channel count restricted by baud rate (and event interval). Check the wiki for more info
- Controller boards using serial
- Renard8
- Renard16 (Xmus16)
- Renard24
- Renard64
- Firegod
- DMX
- Advantages:
- High channel count (512)
- Large distance from computer to first controller
- Compatible with other commercial DMX devices
- Disadvantages:
- Requires external device (dongle) for DMX transmission (not always inexpensive)
- Controller boards using DMX
- Lynx
- Lynx Freestyle
Step 6: Determine board availability
- Most controller boards are available via coops that are held by the designers at various times of the year. Check out the Coop Forum for which boards are currently being coop’d.
- The Grinch and Renard64 boards are available on a regular basis. PM wjohn for current availability and pricing.
- If the board of your choice is not currently available then you might consider doing a home etch of the board yourself. But be aware that not all boards are capable of being home etched.
- You can also ask around and try to locate someone who has a spare board that they might be willing to sell to you.
Step 7: Determine cost of proposed solution
- Go to the Comparison_of_DIY_Boards page and calculate an estimate for your tentative solution.
- If the cost figure is within your budget and you are comfortable with it, then press on.
- If the cost figure is higher than you expected, you can either look at another controller to see if a cost savings can be had or you can start all over and redesign your display to match your budget.
Congratulations!! If you followed the above steps you should now know exactly which controller board (and how many) you want to build. Now all that is left to do is buy the boards and parts and start building.
Good Luck! And Happy Lighting!
