Different Styles of Pixels
It is critical that you select a  Pixel Controller and Power Supply that is compatible and capable of driving the specific Pixel you select.  It is also important to consider how you will be connecting the Pixels and if you need Power Injection to make them function.
Pixel Properties
Form Factor
- Strings - Can be any purchased in any custom length, but more then 50 pixels will require Power Injection.  It important to remember that Pixel strings should never be strung using their wire to support them like you would with regular light stings.  This will damage the Pixels and their waterproofing.  Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. Common methods to support Pixel strings include using cable ties or electric tape to attach them to PVC pipe, EMT electric conduit or Plastic Strapping.   Strings are commonly used to make Megatrees, Minitrees and Leaping Arches.
- 12mm pixel - This is the most common Pixel type.  They are often referred to as Bullet Shaped. It actually contains a 8mm LED inside the housing.  The 12mm refers to the outer diameter of the package.  These were orginally designed to mount inside of enclosures and are used for large advertising display screens.
 - 12mm pixel (square) - These pixels can come with the wire coming either out of the back of the Pixel or the side of the Pixel.  There has been some issues with the silicone injection molded units that have the wires coming out of the side not sealing and allowing water into the pixels.
 - Pixels with Lens - There are a variety of Pixels available with Plastic Lens mounted on the RGB LED to make them look closer to a traditional C7 or C9 incandescent light. Common models include the Ge Color Effects (GECE), the Pixabulb by diyledexpress.com, the Cosmic Color Bulbs by Lightorama.com and the Technicolor Pixel by Ray Wu. Vendors like Ray Wu also sell Plastic lens that can be glued onto regular 12mm Pixel strings to achieve a similar look.
- Strips - Are long flat flexible PCBs that have the RGB LEDs and the IC mounted directly on them and there is no wire between the Pixels other than the PCB.  They generally come in 5M lengths.  Depending on the Pixel IC used, from 1-3 RGB LEDs will light for each Pixel, so they can end up looking more like Dashes (- - - -) when there are 3 RGB LEDs per Pixel vs. Dots (.. . .) when there is 1 RGB LED per Pixel.   Many strips can be cut shorter, but you must only cut at the marks on the strip identifying where they are cutable.  You may have to solder wires to the PCB if you are doing Power Injection or cutting the strips.  It is very helpful to use flux and a smaller soldering iron so you do not damage the delicate pads on the flexible PCB.   Strips are commonly used to make Pixel Matrix on Flat Surfaces or as  outlines around doors and windows.
 - Hollow Tube - This is the most common Pixel Strip.  They are basically the uncoated Bare Board Pixel Strip pulled into a hollow Silicone Tube.   You must use some form of Waterproofing like neutral cure GE Silicone II to seal the ends where the wires attach to the PCBs.
 - Coated Strips - The bare PCBs are also available with a variety of waterproofing compounds.  You need to scrape away the waterproofing compound to solder the wires to the PCB to power them or to cut them.
 - Epoxy Resin Coating
 - Solid Tube - The bare PCBs are also available in hollow tubes that have been filled with various waterproofing compoounds.
- Solid Silicone
 - Solid Epoxy Resin
- Modules - Are very similar to strings, but are designed to be mounted to some surface and often have mounting tabs. They commonly have multiple RGB LEDs per pixels, so they are brighter then regular strings. Most are designed to run on 12VDC. Since they are generally custom made, you can request your vendor to make the spacing between units to custom lengths. They are frequently waterproofed by filling then with epoxy. They can come in metal or plastic housings. Modules are frequently used for lighting tune to signs, outline large objects and backlight Coro designs.
RGB LEDs per meter
 - Strings - Strings come in all different shapes and sizes of Pixel nodes.  On common 12mm Pixel nodes there is only one RGB LED in each node, while some of the other shapes and modules often have multiple RGB LEDs inside.
LED Type
- 3528 - These are surface mount LEDs that are each 3.5mm x 2.8mm.  These are the smaller of the two surface mount LEDs and are noticeably dimmer then the larger 5050 LED.  These are frequently found in strips and modules and some strings like the GECE.
 - 5050 - These are surface mount LEDs that are each 5.0mm x 5.0mm This is the most common LED used in  strips and modules and some strings like the Pixabulb (which has two LED per bulb!).  They are quite a bit brighter than 3528 LEDs.  Some of the newer IC types like the WS2812 have the 5050 mounted directly on top of the Control IC.
 - 8mm - This is the type of LED typically used in 12mm and Square Pixel strings.  Due to the plastic diffusion lens on the LED, they do a good job in dispersing the light in all directions.
Waterproofing
- Injection Molded Silicone - These units have the wires coming out of the back or side and the biggest issue has been the failure of the silicone used to seal to the wires.  Many early pixels had obvious areas where water could easily get into the Pixels.  While many of the newer unts have better sealing, there is always the potential for the water to wick in along the wires if there is any stress on the wires due to wind pulling on the wires.
 - Cast Epoxy Resin in Sleeve - The most recent Pixels now come with the Pixels located in a plastic sleeve that is filled with a solid epoxy material.  The hard epoxy seals well to the wires and many believe that results in a more waterproof pixel compared to Silicone Injection Molded Pixel strings.
 - Cast Epoxy Resin coated PCB - This is the most common method of sealing Pixel Modules and many of the newer Pixel strings with Lens on them like the Pixabulb.  These units have had good success in not failing in the weather.
 - Coated Strip - There are a number of cast coatings that can be applied directly tot he bare PCB at the factory.  There has not been a lot discussed about how these strips hold up under weatehr either good or bad.  They are just not as common as Pixels, but there are quite a few Dumb RGB strips that use this approach to weatherproofing.
Wire Size
 - Color Depth - The number of bits of color information used by the IC Type determines the  Number of discrete colors you can make with the Pixel. Higher bit counts allow smoother fades and allows more colors to be generated.
 - LPD1101
 - UCS6909
 - UCS6912
- LPD8809 ?
 - SM16715
 - P9813 - 4 wire
 - P9816 - 4 wire
 - TLS3002
 - CYT3001 Datasheet (Chinese)
 - CYT3005 - 3 wire
 - MY9942 (Native DMX)
 - MY9943 (Native DMX)
DIYLEDEXPRESS
HolidayCoro.com
| String/Node/8mm/Bullet | WS2811 | 50 Pixels (12'-6") | 12 vdc | 13 | 13 | Product Page | IP68/Cast Epoxy+Silicone Sleeve, 8mm LED/12mm Base | |
| String/Node/8mm/Bullet | WS2811 | 50 Pixels (12'-6") | 5 vdc | 13 | 13 | Product Page | IP68/Cast Epoxy+Silicone Sleeve, 8mm LED/12mm Base | |
| String/Node/8mm/Flat Base | WS2811 | 50 Pixels (12'-6") | 12 vdc | 13 | 13 | Product Page | IP68/Cast Epoxy+Silicone Sleeve, 8mm LED/12mm Base | |
| String/Node/8mm/Flat Base | WS2811 | 50 Pixels (12'-6") | 5 vdc | 13 | 13 | Product Page | IP68/Cast Epoxy+Silicone Sleeve, 8mm LED/12mm Base | |
| Module / Rectangle | WS2811 | 1 Pixel | 12 vdc | 30 | 10 | Product Page | IP68, 3 of 5050 RGB LEDs, 6" Wire Spacing,IP68/Epoxy Sealed | |
| Module / Square | WS2811 | 1 Pixel | 12 vdc | 36 | 12 | Product Page | IP68, 3 of 5050 RGB LEDs, IP68/Epoxy Sealed, Stamped Steel Base | |
| Strip | WS2811 | 50 pixels (5m/16.5 ft) | 12 vdc | 30 | 10 | Product Page | IP68/Silicone Tube, Black or White PCB Colors, EpiStar LEDs | |
| Strip | WS2811 | 80 pixels (5m/16.5 ft) | 12 vdc | 48 | 16 | Product Page | IP68/Silicone Tube, Black or White PCB Colors, EpiStar LEDs | |
| Strip | INK1003/WS2811 | 150 pixels (5m/16.5 ft) | 12 vdc | 30 | 30 | Product Page | IP68/Silicone Tube, Black or White PCB Colors, EpiStar LEDs | |
| Strip | INK1003/WS2811 | 240 pixels (4m/13.1 ft) | 12 vdc | 60 | 60 | Product Page | IP68/Silicone Tube, Black or White PCB Colors, EpiStar LEDs |
Light-O-Rama (LOR)
(USA Based)
Ray Wu
Retail Store (i.e. Lowes)
Seasonal Entertainment
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| Nodes / Sring | 50 nodes (5m) | 12vdc | link | ||
| Strip | 5m | 12vdc | link | silicone tube | |
| Module (rectangular) | 20 nodes | 12vdc | link | 3 LEDs | |
| Module (square) | 20 nodes | 12vdc | link | 3 LEDs |
Ray Wu
(China Based)
Ray Wu
(China Based)
Waterproofing Pixels
Null Pixels
