When you're working with Pixels, Dumb RGB or any type of LEDs, they need to be run on DC voltage. To do that you will need to run some sort of power supply. There are many types you can use. A power supply converts high voltage AC power from your wall outlet (commonly 115VAC in North America) to a lower voltage DC current to drive your pixels. There are four main properties to a power supply:
- Waterproofing
 - Input Voltage
- 120 VAC (nominal)
 - 240VAC (nominal)
- Multivoltage
- 5VDC
 - 12VDC
 - Output Current
Power Supply Voltages
You must buy a power supply with the correct voltage to match your pixels and controller. Using the wrong voltage can destroy your pixels and controller by hooking them up even once to the wrong voltage!!
With 5v the voltage drop due to the wiring will be noticeable if you're trying to push the voltage for a long run. Most likely you will need to inject the power again or feed from the center of the pixel string. For every 50 pixels, you should re-inject the power. So a good example, if you have a 100ct pixels string you can connect the signal wires end to end, but you will either have to put the power at the center of the string to feed each side. or you will have to put a power source on either end. A 50ct pixel string will pull around 3amp (50x.06=3amp). So really finding smaller power supplies is a good thing to have if you have your pixels spread around the yard. If you have like a pixel megatree then you can do a large power supply to feed the whole tree. So bigger is not always better esp if your not power a lot of pixels close by.
12 volt is a bit different. You can push 12v further than 5v. So that does have its advantages and disadvantages. Most pixels strings are now available in 5VDC and 12VDC. 12VDC power supplies are typically more expensive per amp of current. Also many 12vdc strings waste a lot of power as heat and not light, so they are not as efficient as 5VDC strings.
Power Supply Current
Waterproof Power Supplies
Waterproof power supplies are really nice in the sense that you do not have to really worry about moisture as much as a non waterproofed power supply.  Before placing a "waterproof" power supply in a weather exposed area, check it's IP rating to determine what level of protection is required.  You should still put it in some sort of shelter just to be safe.  These are a little more pricey than a standard switch mode power supply but alot less headache.  They come in a variety of sizes so you will have to choose what will work best for you.
Examples of Waterproof Power Supplies available from different vendors
Pricing is in US $.  Pricing is as of 6-24-13.
| 5VDC | ||||||||||
| 12VDC | ||||||||||
| Holiday Coro | 45W Waterproof Switching Mode | 100-130 VAC | 12VDC | 3.75A | w/o Cord or With Cord | $12.39 | $3.30 | 1"x1.2"x9.7" | IP68 | |
| 24VDC | ||||||||||
Non Waterproof Power Supplies
Since they are not rated as waterproof, you must use these supply in some form of enclosure if you want to use these outside to power your DC LEDs.  There are many types of Enclosures that you can mount your power supply inside of including the [CG-1500] provide a large enclosure that you can mount both a power supply and a controller inside of. Most of the supplies have a small adjustment potentiometer that you can use to adjust the voltage output slightly.
| 5VDC | ||||||||||
| Holiday Coro | 350W Switching Mode | 100-130 VAC | 5VDC | 60A | link | $32.95 | $0.55 | 2"x4.5"x8.5" | Fan Cooled | |
| 12VDC | ||||||||||
| Holiday Coro | 350W Switching Mode | 100-130 VAC | 12VDC | 29A | link | $29.95 | $1.03 | 2"x4.5"x8.5" | Fan Cooled | |
| 24VDC | ||||||||||
Converting ATX Power Supplies from a PC
One common low cost way to generate +5VDC and +12VDC is to convert an old used PC power supply that you have salvaged from an unused PC.  Since these power supplies were designed to work inside of a PC, you need to come up with an enclosure to mount them in.  There are many types of Enclosures that you can mount your power supply inside of including the [CG-1500] which can provide a large enough enclosure that you can mount both a power supply and a controller inside of.  There are numerous plans available on the internet showing you how to convert ATX PC Power Supplies. For more information see:
Wall Warts
Wall warts have limitations and are difficult to try to run pixels off of. First off most are too small to supply enough amperage. Also they do not supply very clean or stable power to the pixels. Your best bet is to stay way from them.
DC - DC Converters
Buck Converter
Boost Converter
Power Supply Connections
Power supplies generally have screw terminals or wires from the power supply that you can connect to your controllers.  Your power supply may vary, but common markings include:
DC Power Supplies are capable of putting out hundreds of watts of power and causing serious damage, always use properly sized fuse for safety! Due to the very high current that many power supplies are capable of putting out (>60A) it is a good design concept to use a heavy gauge wire inline fuse holder between the power supply and the controller hookup. The large gauge wire will minimize any voltage drop that may occur in the wire due to high current. The fuse is a safety factor to prevent the full power from the power supply from discharging thru a short circuit and potentially causing a fire. The correct size fuse rating should be selected based on the expected power usage of the units hooked up to the power supply. It is common to use 12-14ga wire to connect power supplies with high count pixel controllers like the E682.
Mouser.com carries several inline weather resistant fuseholders that take automotive blade style fuses both ATC and Mini style fuses. You can also find similar fuseholders at Radio Shack, your local auto parts store, Ebay, or DX.com.
| Fuseholders | ||||||
| Current Rating Up to  |
Wire Size | Fuse Type | Mouser Part #  | |||
Choose the fuse and fuseholder based on the maximum current that you expect from your Pixels to draw thru that section of wiring. For more information about fuse size or style selection look here or here.
- ATC  and ATO fuses are available with ratings of 1, 2, 3, 4, 5, 7 1/2, 10, 15, 20, 25, 30, 35 and 40A.
Wire Sizing in Pixel Systems
It is desirable to use the largest wire diameter (smaller wire gauge AWG) that you can when connecting your pixels to your controller.  The higher wire gauge results in a higher voltage drop and can cause your pixels to have poor colors or to not function at all. The voltage drop is caused by the resistance in the wire and is  calculated by Ohm's Law.  This is a good thread that discusses voltage drop.
A simple example is how you choose the right size wire between the Pixel Controller and the Pixel string/strip.  You can  use the data from the table below to estimate your voltage drop based on the current and wire gauge you will be using.  For example:
Common wire used for Pixels include larger gauge (10-18 AWG) Speaker wire, Security Alarm Wire, Low voltage landscaping wire, Sprinkler wire, SPT wire and various wire types available from the pixel vendors.  You must pay attention to the wire size (thicker is better) and length (shorter is better) to ensure that the voltage drop over the wire is not excessive.   Do not use thin wire (20-26 AWG) like Cat5 or Cat6 wire.  The voltage drop over thin wire is often too high to allow the pixels to operate properly.  Thin wire also is a safety hazard and can heat if too high a current is used on it.
| AWG Gauge | Conductor  Diameter Inches  |
Conductor Diameter mm  |
Ohms per foot  |
Ohms per meter  |
Maximum Amps for Chassis Wiring  |
Maximum Amps for Transmission  |
Waterproofing Pixels
Null Pixels
