Ren64TW
Ren64TW - in development.
- The Ren64TW is a 64 channel board, using external SSRs. It has an on board power supply, and optional XBee support.
- This board is currently in development by J. Bolding (bolwire). An initial run of 10 pcbs has been ordered for testing and verification.
The Board
- The board measurement is 5.825"W X 5.500"H, and the provided mounting holes are placed to align with a CG-1500 demarcation enclosure.
Board Availability
- The Ren64TW is currently under development and not available at this time.
 - Inquires should be directed to bolwire here on the DIYC forum.
 - PCBs should be expected to be available no earlier than June 2014, however if that changes I will update as needed.
Bill of Materials
- The BOM project at Mouser contains all parts needed, except the optional XBee module.
 - You can find the Mouser project BOM here
PART NUMBER
(Mouser PN#)QTY REF NOMENCLATURE 511-L4941BV 1 U1 LDO Voltage Regulators 5.0V 1.0A Positive 534-3517 2 F1 Fuse Clips PC FUSE CLIP 5 MM 534-3527C 1 F1 Vinyl Fuse Cover 504-GMA-1-1/2 1 F1 Cartridge Fuses 250VAC 1.5A Fast Acting 511-1N5817 4 D1-4 Diode Vr/20V Io/1A 291-750-RC 2 R1-2 Resistor - 750ohms 1/4W 5% 291-120-RC 1 R3 Resistor – 120ohms 1/4W 5% 299-1K-RC 2 R4, R7 Resistor – 1K ohms 1/8 W 5% 299-27K-RC 3 R5, R8-9 Resistor – 27k ohms 1/8 W 5% 299-680-RC 2 R6, R10 Resistor – 680 ohms 1/8 W 5% 299-33-RC 1 R11 Resistor – 33 ohms 1/8 W 5% 264-330-RC 1 RN1 Resistor Network 6 pin 330 ohm 1/8 w 2% 838-3FS-412 1 TF1 Power Transformer 12.6VAC CT 6.0VA Single Primary 571-7969492 1 120V N Power Terminal 78-1N5229B 1 D5 Diode, Zener 4.3V .5W 78-1N5239B 1 D6 Diode, Zener 9.1V .5W 78-1N5226B 1 D7 Diode, Zener 3.3V .5W 511-L4931CZ33-AP 1 U14 LDO Voltage Regulators 3.3V 0.25A Positive 571-1-390261-3 8 U6-13 14 Pin IC Socket 571-1-390261-2 2 U4-5 8 Pin IC Socket 571-1-390261-1 1 U2 6 Pin IC Socket 571-5556416-1 19 J1-2, SSR Ports RJ 45 Top Entry 649-10090099-S094VLF 1 JDP1 DB 9 Right Angle 815-ACH-18.432-EK 1 U3 Oscillator 511-ST485BN 2 U4-5 ST485BN 604-WP710A10IT 1 PWR Standard LEDs - Through Hole Red 60mcd 625nm 60 deg Transparent 604-WP710A10GT 6 +5 GND 1 2 3 4 Standard LEDs - Through Hole Grn 60mcd 568nm 34 deg Transparent 782-H11AA1 1 U2 Transistor Output Optocouplers Bi-Directional Input 140-REA332M1CBK1325P 1 C1 Aluminum Electrolytic Capacitors - Leaded 16V 3300uF 20% 12.5x25mm 140-REA470M1CBK0511P 1 C2 Aluminum Electrolytic Capacitors - Leaded 16V 47uF 20% 5x11 mm 80-C322C104K5R 9 C3-11 Multilayer Ceramic Capacitors MLCC - Leaded 50volts 0.1uF 10% X7R 579-PIC16F688-I/P 8 U6-13 8-bit Microcontrollers - MCU 7KB 256 RAM 12 I/O 538-22-03-2021 4 JP1-2, JP4-5 Header 2P 538-22-03-2031 2 JP3, JP6 Header 3P 151-8000-E 6 Jumpers 2 POS Shunt 532-577102B00 1 U1 Heatsink M22-7131042 2 Xbee Xbee header
Board Assembly
Jumper Configuration
- The Ren64TW has a jumper for just about any configuration you would like to use.
- Jumper JP1 & JP2:
- For RS-232 (direct to PC) JP1 ON/JP2 OFF
 - For RS-485 (output from renard board or converter/adapater) JP1 OFF/JP2 ON, Try removing JP2 if communication issues occur.
- Jumper JP3: Selects weather the incoming data is from a wired connection or XBee module
 - Jumper JP4: Enables XBee transmit
 - Jumper JP5: Resistor bypass for XBee incoming data
 - Jumper JP6: Selects the standard renard method of passing data to the next controller, or to use bypass (thru) for DMX and Start Address firmware use
Test Port
Using the optional XBee support
Schematic Diagram
- For SSR Ports Diagram see Media:Ren64TW_Diagram_P1.pdf
 - For Power Supply, Communications, Oscillator & Test Port Diagram see Media:Ren64TW_Diagram_P2.pdf
- The Ren64TW uses any version of the Renard firmware that other Renard series boards are able to use.
 - The firmware page is here.
