Using Audacity Labels
HLS can import Audacity labels to help automate precise beat track creation. First, make sure you have installed the Queen Mary Vamp plugins: http://vamp-plugins.org/download.html
HLS_Audacity_Beat-tracker.PNG Creating a Label Track in Audacity:
- Open Audacity and open your mp3 file.
 - Click Analyze -> Bar and Beat Tracker: Beats...
 - The window shown in image 10.5-1 will appear. Select the beats per bar. This will place the specified number of labels for each measure of music. For example, if you choose 4, and there are 4 beats per measure in the song, you will have one label for each quarter note. Setting this to 8 would give you one beat for each eighth note, etc.
(Audacity will now analyze the file to determine the beats.)
- Once complete, you will see the label track that has been created.
 - Click File -> Export Labels.
 - Save the resulting text file. (Perhaps create a "Label Tracks" subfolder in the HLS main folder.)
- Open HLS and either open the sequence that uses that audio, or create a new sequence using that audio.
 - Open Channel Manager (Manage Channels -> Manage Raw Channels).
 - Click Add Control Channel. Window X-X will appear.
 - Select "word" and click OK.
 - Scroll to the word channel and name it something meaningful (such as Audacity). Click DONE WITH CHANGES.
 - Add the Audacity channel to a display group and make that display group active.
 - Right-click on the first cell in the word channel and select Add Audacity Label Track File.
 - Tip: Add the channel to the beat channel group or make it sticky so you can use it as reference.
