Different Styles of Pixels
There are many options and configurations and each has it's advantages and disadvantages depending on the application. Some of the most popular Pixels are ones driven by the WS2811 IC and use 12VDC power and use some form of cast epoxy waterproofing. They are a good balance of new technology and reliable designs.
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8809
- SM16715
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS
Light-O-Rama (LOR)
(USA Based)
Ray Wu
(China Based)
Retail Store (i.e. Lowes)
Seasonal Entertainment
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $32.50 | $0.65 | ||
| Strip | None | 5m | 12vdc | 30 | 0 | link | $49.99 | $10.00/m | silicone tube and coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $25.80 | $1.29 | 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $27.80 | $1.39 | 3 LEDs |
Ray Wu
(China Based)
Ray Wu
(China Based)
