Using a formula called Ohm's Law you can calculate the effect of the voltage drop by entering in the wire size and the power drawn by the LEDs or Pixels. It is important to choose the correct Wire Size for your layout to minimize voltage drop. There are online tools like the Voltage Drop Calculator that can assist you in calculating the impact of the wire size vs. power needed.
General Rules
- Always use the proper size fuses and fuse holders to protect your system from damage.
 - Use the largest diameter (smallest AWG wire gauge) that you can to minimize voltage drop to circuits.
 - DO NOT TIE TOGETHER POSITIVE (V+) OUTPUTS FROM DIFFERENT POWER SUPPLIES!!
 - DO TIE TOGETHER NEGATIVE (V-) OUTPUTS FORM DIFFERENT POWER SUPPLIES AND PIXEL CONTROL SIGNAL FEEDS.
 - Only connect one power supply to each LED or Pixel string.
 - Using the correct Wire Size will often allow you to use up to 50 5VDC Pixels and 100 12VDC Pixels without Power Injection.
 - Choose Power Supplies that have have a high enough current rating for your system.
Pixel System Power Components
- Power Supply
 - Power Supply to Pixel Controller Power Wiring and Fuses
 - Pixel Controller
 - Pixel Controller to Pixel Power Wiring, Pixel Connectors and Fuses
 - Pixel String Wiring
 - Power Supply to End of Pixel String Power Injection Wiring and Fuses
Single Power Supply Power Injection
<50 Pixel String
>50 Pixel String
Multiple Power Supply Injection
<50 Pixel String
>50 Pixel String
Different Styles of Pixels
