E1.31 Bridge
Revision as of 16:11, 11 July 2013 by Jklingert (talk | contribs) (FAQ)
This is a work in progress!!!!
The 6-port E1.31 bridge is a device that takes in an E1.31 stream from your network and converts (or 'bridges') that to multiple DMX or Renard output streams. E1.31 or sACN (Streaming Architecture for Control Networks) is a method of multiplexing multiple DMX streams over your network using unicast or multicast UDP packets. The 6-port bridge currently only supports multicast streams. This makes it simpler to configure but has drawbacks in very large configurations (10's of streams). E1.31 can support 63,999 DMX streams or 'universes' (64000->65536 are reserved) so it has a virtually unlimited amount of expansion available.
6 Port E1.31 Bridge Parts
Mouser BOM
Part IDMouser PNDescriptionQty
R1-R3291-220-RC Carbon Film Resistors - Through Hole 220ohms 0.05 3
R4-R9 291-120-RC Carbon Film Resistors - Through Hole 120ohms 0.05 6
R10-R12291-10K-RC Carbon Film Resistors - Through Hole 10Kohms 0.05 3
C1-C3 140-REA470M1VBK0611P Aluminum Electrolytic Capacitors - Leaded 35V 47uF 20% 6.3x11mm 3
C4-C12581-SA105E104MARMultilayer Ceramic Capacitors MLCC - Leaded 50volts 0.1uF 20% Z5U 9
IC1619-P8X32A-D40 32-bit Microcontrollers - MCU DIP pkg Propeller Chip 1
IC2579-24LC512-I/P EEPROM 64kx8 - 2.5V 1
IC3-IC8511-ST485BN Buffers & Line Drivers Hi-Spd Lo Pwr Trans 6
IC9579-24AA025E48-I/SN EEPROM 2K 256 X 8 1.8V SERIAL EE, IND 1
X1520-HCU500-20X Crystals 5MHz 20pF 1
Wiznet950-WIZ820IO Ethernet Modules W5200 & MAG JACK ioPLATFORM MODULE1
LED1604-WP7113GD 604-WP7113GD 1
LED2-LED3604-WP7113ID Standard LEDs - Through Hole HI EFF RED DIFFUSED 2
VR1580-OKI78SR5/1.5W36C DC/DC Converters 7.5W 24Vin 5Vout1 1.5A SIP Non-Iso 1
VR2511-LF33CV Low Dropout Regulators - LDO 3.3V 0.5A Positive 1
Heatsink 532-577202B00 Heat Sinks TO-220 HORIZ/VERT SLIM CHANNEL STYLE 1
S1-S2653-B3F-1000 Tactile Switches 6X6 Flat 4.3mm Btn Force 100g w/o Grd 2
IC Socket 1575-199640 IC & Component Sockets 40P TIN PIN TIN CONT 1
IC Socket 2 - IC Socket 8575-1104331610003000 IC & Component Sockets 8P DIP SOCKET SOCKETS 7
JP1571-826629-3 Headers & Wire Housings 3P SINGLE ROW 1
H1571-826629-4 Headers & Wire Housings 4P SINGLE ROW 1
Wiznet 1x6 Header517-9601066202AR Headers & Wire Housings 6P STR SR BDMNT SKT 3.0MM TAIL/7.1MMBODY 2
2x3 Output Selector 855-M20-9980345 Headers & Wire Housings 03+03 DIL VERTICAL PIN HEADER GOLD HT 12
TB1571-2828372 Fixed Terminal Blocks 5.08MM PCB MOUNT 2P 1
J1-J6571-5556416-1 571-5556416-1 6
Output Shunts517-9691020000DA Headers & Wire Housings 2.54MM SHUNT 25
The BOM is also available at a discount from DIYLEDExpress.com
The 6 Port E1.31 Bridge requires a fair bit of soldering so take your time and ensure you install the components in the correct orientation when required. Start by sorting the components by type and values. Look over the PCB before starting noting the location of the various components. Follow the standard procedure of installing the lowest profile parts first and ending up with the tallest.
  1. Install the MAC IC, this is the only surface mount IC. It is optional if you are not comfortable with soldering surface mount ICs.
  2. Install the 0.1uF (100nF) capacitors C4-C12.
  3. Install the 220 Ohm resistors (red, red, brown, gold) R1-R3.
  4. Install the 120 Ohm resistors (brown, red, brown, gold) R4-R9.
  5. Install the 10K Ohm resistors (brown, black, orange, gold) R10-R12
  6. Install the 5Mhz Crystal X1.
  7. Install the Toggle Switches S1-S2.
  8. Install the seven 8 Pin IC sockets and one 40 pin socket.
  9. Install the green LED LED1. Note that the LED is polarized and the long lead should face towards the top of the board. Note: silkscreen shows "FLAT" side of the LED, this can also be used to check for proper orientation
  10. Install the red LEDs LED2-LED3. Note that the LED is polarized and the long lead should face towards the top of the board. Note: silkscreen shows "FLAT" side of the LED, this can also be used to check for proper orientation
  11. Install the 3.3V Regulator VR2 with the heat sink.
  12. Install the 3 Pin and 4 Pin headers JP1, H1.
  13. Install the two WizNet 1x6 pin headers.
  14. Install the twelve 2x3 output pin selectors.
  15. Install the power terminal block TB1.
  16. Install the three 47uF Capacitors C1-C3.
  17. Install the DC-DC Converter VR1.
  18. Install the six RJ45 jacks J1-J6.
  19. Install the six RT485BN in IC3-IC8 with the notches facing the edge with the power terminal block.
  20. Install the EEPROM in IC2 with the notch facing the edge with the power terminal block.
  21. Install the Propeller in IC1 with the notch facing the WizNet adapter.
  22. Install the WizNet adapter with the socket facing the Propeller IC.
Jumpers
Power Jumper - JP1
Output Configuration Jumpers
Each port has a set of four separate jumpers. These jumpers set the wiring configuration on their respective output jacks. If you want a DMX wiring output, you need to put all four jumpers to the "DMX" side. If you want a Renard wiring output, you need to put all four jumpers to the "REN" side. It is important that all four jumpers are in the same position for that port. Note that the protocol for the port is different than the wired output. You must set the DMX or Renard output protocol via the Bridge configuration settings.
RJ45 Pin Assignments
Output Jumper Settings
Pin # RJ45 Connectors
REN DMX
1 SIGNAL GND RS-485 DATA+
2 SIGNAL GND RS-485 DATA-
3 NC NC
4 RS-485 DATA- NC
5 RS-485 DATA+ NC
6 NC NC
7 NC SIGNAL GND
8 NC NC
You can use the bridge to drive LOR controllers capable of supporting DMX as well. The simplest method is to configure the protocol for DMX and the REN output. You will be required to swap pins 4 and 5 however as LOR has these signals swapped. You may also want to connect pin 6 from the LOR to pins 1 or 2 if using the REN output.
Powering the E1.31 Bridge
Initial Testing
Programming the EEPROM
Current version of the firmware is v2.06 and you can download it here.
The Programming port on the Bridge is the 4 pin header near the WizNet adapter. Match up the silk screen labels with those on the Prop Plug. You will need to externally power the bridge when programming it.
Programming Tools Required
The reccomended way is to use the PropPlug.
PropPlug
You can get it from DIYLEDExpress during Pre-Sales or find it at Parallax or Mouser anytime.
Build your own
Programming Howto
  • Download the Parallax Propeller Tool and install it.
  • Run the Propeller Tool application and it will ask of you want to associate .eeprom files with the application, Say Yes.
  • You can close the Propeller Tool application and double click on the .eeprom file you downloaded or from within the application go to File->Open and change the 'Files of type' to 'Propeller Applications' and open the Bridge_v2.02.eeprom file.
  • A 'Object Info' screen will open, if not already enabled click 'Show Hex'
  • Program the EEPROM on the Bridge by selecting 'Load EEPROM' and you are done.
http://doityourselfchristmas.com/wiki/index.php?title=E1.31_(Streaming-ACN)_Protocol
Configuration Commands
Save
Load
Boot
IP
Subnet
Gateway
DNS
If you are only using DHCP (not recommended), you can leave the static IP areas unused. Network addressing (static or DHCP IP) is only needed to access the configuration page with a web browser. Once configured, no IP address is needed for normal operation. The Default IP Mode, Web Server Mode, No Data Timeout, and Test Pattern commands affect what happens when the system starts up.
Default
DEfault n where n is 0 or 1.
Universe
Protocol
Baud
The Baud command is used to set the baud rate for each of the four output RJ45 jacks. NOTE: This command is only used for the Renard protocol. Baud rate will not be displayed when the DMX protocol is selected.
BAud b n Where b is the RJ45 output jack number, from 1 to 6 and n is 1 for a baud rate of 57,600 or 2 is for a baud rate of 115,200. The Renard protocol refresh rate at 57,600bps for 512 channels is approximately 90ms and at 115,200bps the refresh rate for 512 channels is approximately 45ms. The DMX protocol refresh rate is preset to 25ms.
Mode
"MOde" n Where n is 0 for Multicast or 1 for Unicast
TroubleShooting
Visual Inspection
Power
EEPROM Programming
Communications
Network Configuration
