Renard PX1 Pixel Controller
Revision as of 04:40, 23 April 2013 by Jklingert (talk | contribs) (General)
General
Features
  • Standard Renard connections
  • 5VDC and 12VDC operation
  • WS2801 and WS2811 pixels
  • Some Design Details:
  1. 1) One output (same 3.5mm connector and pinout as jstjohnz's controller), handling up to 200 pixels
  2. 2) RS485 input, same RJ45 pinout and protocol as Renard controllers
  3. 3) 115200 input baudrate (lower rates provided, but not recommended)
  4. 4) Uses PIC16 parts, so existing programmers should work.
  5. 5) Supports WS2811 strings at with either 400KHz or 800 KHz data rate, 5V power input
  6. 6) Uses external 5V supply (readily available from Ebay, China, etc).
  7. 7) Power, RxD and FE (framing error) indicators
  8. 8) Jumper to select pixel speed (400 KHz vs 800 KHz)
The PCB has been designed, with just a few details to be worked out after I receive some connectors to make sure that they fit. I haven't sent the board out for fab yet. The firmware is a work in progress, although I have verified that the microcontroller that I've selected can control the faster WS2811 pixels. First jumper is used to select between a chase and a solid static pattern. Other three jumpers select one of 12 possible themes:
  1. 1) Orange theme (Halloween/Thanksgiving)
  2. 2) Purple theme (Advent/Lent)
  3. 3) Red & Green (Christmas)
  4. 4) Red (or pink) Valentines Day
  5. 5) Green (St. Patrick's Day)
  6. 6) White (Easter)
  7. 7) Red/White/Blue (4th of July)
With five possible other themes (national day colors for other selected countries???)
The number of Pixels that can be supported per serial port depends on both the baud rate and on the frequency of updates that has been programmed into the Vixen sequence. The most common PC control software is Vixen, which easily supports multiple serial ports (including USB-RS232 and USB-485 converters).
Number of Channels (*)
Baud Rate Refresh Interval
100 ms 50 ms 25 ms
115200 383 191 95
57600 191 95 47
38400 127 63 31
19200 63 31 15
PCB Layout
BOM - Bill Of Materials
PartMouser PNDescriptionQtyOptional
R1291-120-RCCarbon Film Resistors - Through Hole 120ohms 0.051
R2.R3299-1K-RCCarbon Film Resistors - Through Hole 1Kohms 5%2
R4,R5299-27K-RCCarbon Film Resistors - Through Hole 27Kohms 0.052
R6260-680-RCResistor Network, 680 Ohm, Bussed, 6-pin1
R7,R8299-47-RCCarbon Film Resistors - Through Hole 47ohms 0.052
C1810-FK28X5R1C105KMultilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10%1
C2,C380-C322C104K5RMultilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R2
D3,D5604-WP710A10ITLED, 3mm Red2
D4,D6604-WP710A10GTLED, 3mm Green2
IC3926-2950CZ-5.0/NOPBLDO 5.0/100mA 1****
J1,J2571-5556416-1Jack, Modular RJ45 PCB Mount Top Entry2
J3,J5,J7.J9538-22-03-2021Headers & Wire Housings VERT PCB HDR 2P TIN PLATING4
J4649-77313-122-10LFHeaders & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH1
J6538-22-03-2061Headers & Wire Housings VERT PCB HDR 6P TIN PLATING1
J8538-22-03-2031Headers & Wire Housings VERT PCB HDR 3P TIN PLATING3
J9571-2828372Fixed Terminal Blocks 5.08MM PCB MOUNT 2P1
J10538-39501-6004Pluggable Terminal Blocks 3.5MM EURO HEADER VE HEADER VERT GRN 4CKT1
Assembly Instructions
  2. Configure Jumpers
  1. Install Resistors
  2. Install Capacitors
  3. Install Diodes
  4. Instal IC Sockets
  5. Install LEDs
  6. Install Headers. The short end of the header is soldered into the PCB.
  7. Install Voltage Regulator
  8. Install Connectors
  9. Install Fuse Holder
  10. Install ICs
    1. Install the 14 pin PIC in
    2. Install the 8 pin RS485 chip in
Configure Jumpers
  • J3- 1x2 DMX Termination Resistor
  • J4- 2x5 Options Connector
  • J5- 1x2 RS232
  • J7- 1x2 Programing?
  • J8- 1x3 5V Bypass
Connections
  • J1 RJ45 Input
  • J2 RJ45 Output
  • J6 1x6 ICSP
  • J9 Power Feed
  • J10 Pixel connection
J1 and J2-Renard Input and Output
NEEDS WORK
Note that the two 3pin DMX connections are setup as a thru connection and can be used as either the input or output of the board. If the LEDancer is the last connection on a DMX data line, it may be necessary to add a 120 ohm terminating resistor to the unused DMX terminals between PIN 2 and Pin 3.
J6-ICSP Programming Header
NEEDS WORK
Pin 1 is the square hole towards the right side of the board closest to D1.
J9-Power
NEEDS WORK
J1 is the 2 pin header located at the top left side of the PCB. The LEDancer can be powered by 5-24VDC. If you are using 5VDC, omit the voltage regulator and jumper the voltage regulator position by soldering a wire jumper to where the two outer pins of the regular would have gone in position U1 near the top left side of the PCB. If you are feeding greater than 5VDC, then you must use the on board voltage regulator.
Round Hole closest to the top of the board: Positive Power feed
Square Hole: Negative Power feed
J10(4 pin)- Output to Pixels
NEEDS WORK
Enclosure
DIYC Flood Discussion Threads
Initial Thread
