Working with Playlists
Playlists are a list of exported illumination data from sequences that you can place in a play order. You can then add playlists into a schedule.
Exporting Illumination Data
- Before a song can be added to a playlist, the illumination data must be exported.
 - Click Output -> Select Output Method and Compile for Show.
 - Verify all universes are assigned to hardware appropriately.
 - In the bottom right, click the Export Illumination Data button (see Figure 9-12).
- Check the Disable Dimming Curves box if you want to ignore any applied dimming curves.
- A window will open listing any master/submaster lighting channels (see Figure 9-13).
 - If you wish these lighting channels to be applied to the export, click the Active box.
- Once all options have been completed, the export completion confirmation will show (see Figure 9-14).
 - Repeat these steps for ALL sequences you wish to use in your playlist.
Adding Exported Songs to a Playlist
- Close down and reopen HLS without opening a sequence.
 - To create your playlist, click Output -> Create a Playlist.
 - The Playlist Window will open (see Figure 9-15).
 - Type in a name for your new playlist.
- Click Select Export File to Play.
 - This will list all of the sequences with exported illumination data (see Figure 9-16).
 - Select the desired file and click ok.
 - The selected file will now be listed next to the Export button (see Figure 9-15).
 - Adjust the Seconds Delay after Song Ends field to the desired time delay.
 - Click Add Song to List to add the song to your playlist with the specified delay.
 - Continue doing this until all songs are added to your playlist.
- If you wish the songs to play randomly, click the Random checkbox.
 - When complete, click OK.
Modifying an Existing Playlist
- To modify an existing playlist, click Output -> Modify Existing Playlist.
 - Select the playlist you wish to modify and click OK.
 - The playlist window will open, allowing you to make changes.
Playing a Selected Playlist
- To play a selected playlist, click Output -> Play Specific Playlist (see Figure 9-17).
- Note: You cannot have a sequence open to perform this action.
 - Click Select Playlist and select the desired playlist.
 - Select Play Now and click the Play Now button.
| Hardware Configuration | Chapter 9: Sequence Output | Creating and Running a Schedule |
