Hardware Configuration
In Revision. Feel free to help!
To output your sequence data to your light controllers, there are specific components that must be defined in HLS output settings:
- Physical Hardware Settings
 - Universe Assignment
 - Output Protocol
Setting Up Com Ports
Setting up a Network
Universe Assignment
Once the physical hardware connections have been defined, HLS needs to know where to send each universe of channel data.
Transport
Protocol
Active
Output Sequence
Hardware Tests
Testing hardware.
