Creating a PixelPlane
What is a PixelPlane?
VIDEO: Joe describes a PixelPlane and creating a PixelPlane in his HLS 2013 Intro video
How to Create a PixelPlane
- First, open the PixelPlane Manager (Manage Channels -> Manage PixelPlane Channels).
 - In the Select PixelPlane Channel window, press the NEW button to create a new PixelPlane (See Figure 6-1).
 - The Manage PixelPlane window will open (See Figure 6-2). Click Create PixelPlane AND Channels.
 - Note: In the past, PixelPlane Channels were first created in the regular Channel Manager. They are now created here. If you have already created channels (in the old way), or are importing from another file and want to convert channels to a pixel plane, select Create/Modify and select your channels manually and then save the changes.
- Once you have created/named your pixelplane, a new button will appear to assign your pixels to a PixelPlane object.
- If you select Vertical Matrix, a dialog box will open confirming you have assigned your pixels to a Vertical Matrix PixelPlane object.
 - If you select MegaTree, a window will open for you to complete some information to help HLS understand your tree setup (see Figure 6-4b]]
- Note: Currently, only "Mega Tree" and "Vertical Matrix" are supported.
| Chapter 5: Sequencing Channels and Adding Effect | Chapter 6: Creating and Using PixelPlanes | The PixelPlane Editor |
